Question about Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic BDW13 dishwasher
I have purchased replacement wheel roller assemblies for the upper basket guides. How do i remove the existing ones? do i need to pull out the unit?
SOURCE: i need to reset my dishwasher but don't know how!!
bdw13 showing e4 & trying to empty when no water in it
Posted on Apr 16, 2007
SOURCE: Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Posted on Jan 23, 2009
SOURCE: simpson silencio 850 dishwasher. not
Halfway and at the end. Put them upside down on the right-hand side to avoid the tray jumping when sliding.
Posted on May 05, 2009
  • 7 Answers
SOURCE: getting error code e3 on display- not reaching
the problem is the heat element, it is to replaes..dont now the prise..i am from denmark...
Posted on Oct 29, 2009
Testimonial: "thanks mate its good to know the problem"
jyackle5
  • 8197 Answers
SOURCE: I Need a user's manual for a Baumatic Dishwasher
You can get the manual here on link below.
http://www.tlc-direct.co.uk/Technical/DataSheets/Baumatic_Manuals/BMBDW13.pdf
Good Luck
Posted on Nov 13, 2009
Testimonial: "BRILLIANT !! THANK YOU VERY MUCH."
Upper rack roller axles are brittle and 1 has
Our upper wheel failed. It is part of the huge assembly called the "Rack Adjust" on our model # PLD4460REC Frigidaire Dishwasher and cost $88 to $120. Hey.. thanks to the guy above I was able to fix my machine without spending to much!! for a huge part when all I needed was the upper wheel. the part # for the upper wheels is = PS976006 and is for another model dishwasher (Sears located it for me first.. without trying to make me buy the huge assembly) but might work... I will order and give them a try. The model # referenced about seems to be incorrect... We used model # PLD2855RFC1... as google helped us fill in the missing part# letters. I asked frigidaire... why they encouraged customers to borrow this small part from the store display.. why not just sell it!! .;)
Aug 02, 2010 | Frigidaire PLD4460REC Stainless Steel...
Error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
May 24, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Error code on my bdw13 dishwasher
Turn off the water and electric!
Its really easy to change the heater element, once you have taken out the dishwasher!, remove the bottom panel and remove the wiring to the element, slacken off the nut under the electrical contacts voila!, also it may be a faulty thermostat that you cannot reset and has to be replaced, I would do this at the same time, as again its easy with the bottom off.
May 03, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic bdw13
the top tray has a nozzle on rear,which pushes into a screw on rubber seal on inside rear of appliance.this splits and stops water being fed to sprayer on top tray.phone baumatic parts dept,only a few pence,but sent mine free!
Jan 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dont know how to clean the dishwasher
go to the dishwashers brand site,click help for your solution.
Jan 05, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Mar 08, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
