Question about Samsung Refrigerators
We have a fridge/freezer model srs758dp 12 months old tongight has started making a huge rattling sound from the back of the unit on certain cycles goes for a fair while when we open freezer door it stops, the freezer light has also blown. Should we turn the unit off however all my food will perrish. Linda Kissick
    Problem Solver:
  • 10 Answers
This sounds occurs due to fan & frost inside the coil
check weather evap.cover has fitted properly.if frost is there defrost the fridge for at least for 24hrs it will work properly
Posted on Jun 14, 2008
  • alsaust Jul 18, 2011
    I have an SRS758DP and it periodically ices up the de-frosting fan. The fan continues to operate, but the plastic blades hit the ice and it makes a shocking noise. Only solution has been to empty the freezer, dismantle the fan from inside rear in the freezer, and mechanically break the ice off. Now that I know how to do it, it takes about 15 minutes.
Sub Zero dripping noise from freezer when cycles off
Is this noise periodically or every time the fridge cycles off? Does it sound like water dripping on a hot surface?
Sub Zero Repair Tucson
Dec 05, 2012 | Sub-Zero 650 / O Bottom Freezer...
GLRT216TAW2 Model Number. Water under vegetable drawers, No other water leaking. Back is dry, Do i need a repair man or new refrig which is only 10 yrs old.
Its the defrost problem.In your unit the defrost cycle is not running on time.This is the procedure of the unit.--- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located.In your case the freezer gets cold, after that defrost cycle has to start, but in your case the defrost cycle is not starting on time so over ice gets internally build and when defrost cycle starts, this ice melts and this gets leaks in the vegetable and under vegetable drawer.-------- Get the defrost timer, and defrost assembly parts checked and repaired by the technician.Repairing will solve the problem.You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 04, 2011 | Frigidaire GLRT216TA Top Freezer...
HELLO I have an LG fridge w/bottom freezer model Problem with the LG Refrigerators I have an LG fridge w/bottom freezer model LRBN22511TT approx 9 yrs old. Actually haven't had any troubles with the...
i think that you have diag the problem it is the relay on the compressor . at it age the relay is worn out . i would replace the relay and if it won't start then it may be the compressor . example out 10 friges with this problem 1 will be the compressor and 9 will be the relay. you can also use a 3 or 4 in on kit these help old comp. start easy and keep them running . mm hope this helped . feed back pls .
Dec 12, 2010 | Refrigerators
Ice on back wall but not freezing food and rattle noise. Moved all food to other freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
May 30, 2009 | Kenmore Refrigerators
Rattling compressor on Kenmoore bottom freezer refrigerator
IF IS NOT 5 YEARS OLD YET CALL A TECH ASAP THIS MODELS HAVE A COMPRESSOR THAT ARE FAMOUS FOR LOCKING UP AND THE ONLY FIX IS TO REPLACE IT BUT FIRST DISCONNECT AND REMOVE BACK COVER AND RIGHT BY THE COMPRESSOR THERE IS A SMALL BOX ATTACHED TO IT CALL A OVERLOAD REMOVE IT AND SHAKE IT IS IF RATTLES THEN JUST REPLACE THAT PART IF IT DOESNT RATTLE CALL A TECH
Nov 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge is cold but always runs.
CHECK THE DOOR GASKETS ON THE FREEZER AND FRIG.,IT SOUNDS LIKE THERE IS A AIR LEAK SOMEWHERE,LET ME KNOW-MIKE
Nov 01, 2008 | Refrigerators
Fridge Freezer very noisy!
cycling every 30 mins is normal. bear in mind that frost free are more noisy as there are fans running as well.
you appear to have temp in freezer too high - should be -18degC
Oct 11, 2008 | Freezers
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Fridge model c373 is rattling. Has been repaired twice to no avail.Sounds like bottles rattling but have removed all items from fridge. Was sent away for repair and when given back had a rattle.
there are two things that come to mind from what you are describing one is the evaporator fan is mialignet and hitting its caseing in the freezer or the condenser fan behind the unit where the compressor is is doing the same thing pull the unit out and check it first as its metal and would give a closer sound as your describing
Jul 22, 2008 | Refrigerators
Loud humming noise as fridge is running
Hey everyone-
I recently fixed a similar problem with my freezer. I searched first and found this and a few other sites which listed this and wanted to provide input for anyone in the future.
I have a GE GSH25JSRF SS. It is about 3 years old. Several months ago I noticed when the evaporator fan in the back of the freezer turned on it would make an awful howling or whistling sound. Basically sounded like what you would hear from the window of an older house if the wind outside was blowing real strong. It was loud enough to hear on the other end of the house.
I was convinced that it HAD to be the air blowing over the venting or a gap that created that sound. But I read different solutions on the internet and decided to take a chance on simply replacing the evaporator motor and attached fan blade. That solution worked and my house is quiet again, thank god.
I ordered the parts from a supplier on the internet. Keep in mind, though, if you're not real handy it may be more than you bargain for. Might be easier to have a service guy come out.
I'm still not sure exactly what aspect of these parts caused the howling sound. It could be a bearing within the motor or perhaps the fan blade slipping due to wear. Either way, it's fixed now. Just wanted to share. Thanks.
Oct 04, 2006 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
167 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
