Question about LG Prada KE850 Cellular Phone
LG Prada Loud Speaker & Exculating Ring Tone
I can't get an external speaker to work and how do you stop the exculating ring tone I want it normal volume from the start.
Ken
  • Kenstarsix Jun 21, 2008
    Thanks for trying but the problem is that the ringtone is at maximum but is still so quiet as well as being assending which means that for the first 20 seconds it can't be heard even when held in your open hand. I don't think there is an external speaker on this phone I beleive you can't hold it away from your ear. Or do you know different???
  • Levi Handsford Aug 28, 2008
    The speaker on my LG Prada mobile phone doesn't work. I can't play music or hear anything when on the phone. Do you know where I can get a new speaker or how I can sort this problem. Many thanks
Press the lock key on the side during a call to activate the speaker phone option and then press the required touch button on the screen.
Piyush
Posted on Dec 17, 2008
If you're on a call click the button on the left of the phone that's just below the volume keys the option for speaker will appear on the screen.
Posted on Aug 08, 2008
You have to go to profiles and then personalise the profile. You can edit the volume of the ringtone from there.
Posted on Jun 20, 2008
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Tip
Audio files/MP3 and ring tones
Discovery: You are able to download wave files (and other audio file types) to your phone and even be given the feature, 'set as ring tone' -DONT.
You will find that your phone malfunctions if you set anything other than an MP3 from your phone's MP3 folder, as a ring tone.
It's the fault of the phone's firmware that leads you to believe you can select a ring tone from an audio file that is stored outside of the MP3 folder.
 It is also evident, with the limited memory the phone itself has to store MP3s, that you will NOT be able to personalize ring tones for every contact in your phone book!  Again, this is not explained in the manual properly and has led to much confusion surrounding MP3 functionality on the Prada LG.
I hope this helps.
on Jan 04, 2008 | LG Prada KE850 Cellular Phone
My external speaker will not work
Hi, what causes the phone not to be able to ring out is due to the ringer inside the phone that allows you to hear a ringing tone and can be used as external speaker too.it's bad.
You will need to replace the ringer inside the phone. When replaced phone will start ringing out and you can hear when it rings out.
have a nice day.
Aug 31, 2010 | LG Xenon GR500 Cell Phone
LG GC900 stuck on silent
Hi
Since you have done all the necessary checks and the phone still stays on silent, then the problem is from the speaker which is where ring tones come out from when you receive a call or text message
The solution is to have the speaker replaced because it is no longer working. A repairer can help you replace it if you cant do it yourself.
Cheers
Mar 11, 2010 | LG VX3100
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
It has low ring that i can not hear it ringing
The ring tone volume on the X1 is not very loud you will just have to choose a loud ring tone that will catch your attention. Have you tried putting both the phone and ring tone volume up by pressing the speaker symbol at the to of the screen and putting both sliders up full.
Jul 18, 2009 | Sony Ericsson XPERIA X1 Smartphone
NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
May 20, 2009 | NEC Dterm DTP 16D-1 Corded Phone
How do I use speaker phone on the LG KF310?
To turn speaker phone ON/OFF during a call, press and hold navigation "OK" button.
To set ring tone go to 9. Profiles > select > Personalize > Call Alert Type.
Apr 01, 2009 | LG KF310 Cellular Phone
My Nokia 6085h will not ring out loud.
there should be a volue control in the phone section of the setup icon turn that up
then if you didnt assign a ring to your groups, try asigning a different ring tone to each group and make sure the ring tones have a loud sound by playing them using the phone.
other than that, it shoud be a hardware problem with the speaker that needs to be replaced.
Dec 29, 2008 | Cell Phones
External Sound Broken
try hitting the speaker it worked on my u400 i know it sounds stupid but it does work don't hit it to hard tho
May 23, 2008 | LG CU400 Cellular Phone
LG Prada KE850 Cellular Phone Logo
438 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
