Question about D-Link Air Plus DP-G310 (dpg-310) Print Server
HP LaserJet 1018 & DP-G310
Xp passes the job to the print queue on the server. Nothing is passed to the printer.
Nothing sent to printer when sending test page on server either.
Server indicates that Printer is online and speed is 480 M bps.
  • 7 more comments
  • ascending8 Jun 11, 2008
    Same problem here too
    when the job is sent it sits in the queue on the server.
    The DP-G310 is a dedicated print server that the printer is connected to. It allows the printer to be available through a wireless network.
    The title gave the information.
  • ascending8 Jun 12, 2008
    The network is 192.168.111.0
    Print server 192.168.111.7
    machine 192.168.111.101
    Jobs are being registered as being in the queue fine, however they are not passing between the server and the printer.
    I have tried this with both
    HP 1022 laserjet
    and
    HP 1018 laserJet
    yep!
    Like I said I can see that the print job went to the server.
    This I did using the http admin pages.
    The printer itself works fine plugged directly into the PC.
  • ascending8 Jun 13, 2008
    1) I have setup dozens of printers in the past, networked and directly connected.
    2) The settings on the PC are correct in that they sends to the print server and can be seen as a queued job on there.
    3) the printer and cable are in full working order. I am able to print fine when the printer is plugged into the back of a PC.
    4) no job passes to the printer when using the web interface on the server to send a test page
    5) sending a test page from the PC just places the job in the queue.
    6) I have reset the server and followed closely the instructions ie plug cables in, then switch on printer, then switch on server, then setup wireless networking.
  • ascending8 Jun 16, 2008
    the rev is C2
    Sorry can't check the port setting I'm off site this week
  • ascending8 Jan 12, 2009
    STAAK PL
    I don't think your solution apply to printers that have been used via the USB
    and have previously been shared from the machine that it was connected
    to, for the previous 3-4 months.
    or are you saying that I need to connect each machine to the print server via USB at least once, and send something to it.
    If this is the case why will the machine that was already connected not work?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Try this:
    If this is hooked up TCP/IP, do you know what the IP address of the printer server is?
    What is the IP address a computer it is connected to?
    I need to know if there addressed properly.
  • Tim Babcock
    What happens when you print a test page from the control panel of the printer?
Best regards to STAAK PL
His solution worked for me
I have a D-link DP-G321 wireless printserver and a HP LaserJet 1018. In the print server compatibility list 1022 was compatible but not 1018 so i tried a lot of things...and i`m so happy that i saved my boss from paying a bad choice when ordering the print server. thank you very much
STAAK PL wrote "
1. Connections and installation for printserver and printer should be made according printserver manual
2. If everything is OK (only wireless connection between printserver and acces point) lamps >power< and >wlan< on printserver should be lighting
3. during sending anything to the printer lamp >usb< on the printserver should flashing
... but printer still doesn't print because......there's no "operating sytem" inside printer
Solution
After swiching power on for printer, first printig session have to be make ALWAYS directly from PC via USB. During this operation (you can print only one dot < . >) printer recive "operating sytem" and printing data.
After that you can reconect usb cable from pc to printserver and everything should work."
you will need to set the port from usb virtual to the port you created using tcp / ip port (accoding to your instruction manual)
sorry for my bad english
Posted on Feb 16, 2009
  • D-Link Master
  • 32,281 Answers
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Posted on Jun 11, 2008
  • 1 more comment
  • Chris Hingee
    Chris Hingee Jun 12, 2008
    Do you know the TCP/IP address of your print server?
    Can you Ping that address and get a reply?
    If this is OK then the print server is not communicating with the printer. The printer cable could be faulty also check the print server settings.
  • Chris Hingee
    Chris Hingee Jun 13, 2008
    It appears you are setting up a print server for the first time - my wrong assumption.
    If you had installed the printer by selecting "A network printer or printer ...." and
    then tried to "Browser for a printer" and could not see a printer then try this method.
    1. Install your printer using Add a printer in Printer and Faxes using add printer wizard and install it on LPT1and make it the default printer
    2. Next right click on the installed printer and click on properties.
    3. Click on the Port tab and click on Add Port
    4. Click on Standard TCP/IP Port
    5. Click on New Port
    6. Insert your IP address and Port name
    7. Select Device type (PRINT SERVER)
    8. Click finish
    That printer should now work
  • Chris Hingee
    Chris Hingee Jun 16, 2008
    Also check your network TCP/IP settings of the computers on your network, make sure they are in the same address range as your print server settings.
    ie 192.168.111.xxx
Solution
Best regards
STAAK PL
Posted on Jan 09, 2009
  • 2,794 Answers
Ususally you can get into the print server through internet explorer by typing in the IP Address. For you systems you can type in
Http://192.168.111.7
Its just as good as pinging it but is easier to troubleshoot.
If that doesn't pop up with a printer server screen, there is probably something wrong with the print server.
Are you able to print locally to the printer without the print server?
Posted on Jun 12, 2008
  • 2 more comments
  • Tim Babcock
    Tim Babcock Jun 12, 2008
    I'm going to go download the manual for it and see whats going on.
    You didn't see any error messages on the admin screen?
    Did the configuration settings on the admin screen look correct to you?
  • Tim Babcock
    When you type in http://192.168.111.7 does it tell you what version of firmware it is on?
  • Tim Babcock
    Do you know if your print server has revB on it?
  • Tim Babcock
    In the control panel of the printers there is a port assigned and check off for the printer listed as 192.168.111.7 under the settings?
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
Communication between PrintServer DP-301U and HP LaserJet 1020
Trying turning your printer off and then back on. It happens sometimes that the print server looses the printer.
Alex
www.CAS411.com
Feb 13, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    DP301U COMPATIBILITY
    I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
    LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
    Feb 09, 2009 | D-Link DP 301U (DP-301U) Print Server
    I have a d-link DP 301u can't print to printer
    found it just not to be a good product could not get it to work properly.
    Took a netgear ps121 and had it connected and working in less than 5 minutes and could use the manager sofrare that came with the printer.
    Jan 02, 2009 | D-Link DP 301U (DP-301U) Print Server
    Cannot print on shared printer
    I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
    Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
    Oct 26, 2008 | HP LaserJet 1018 Printer
    Configuring a Mac Book Pro laptop with a DP 300U Print Server
    I connected my HP5MP to the DP-300U LPT1 port.
    I configured my port on the DLink Configuration tab, giving it a name "hp5"
    ...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
    On my Mac, I go to System Preferences > Print & Fax
    Click the + to add a new printer
    Select the IP option
    Choose the Protocol: Line Printer Daemon - LPD
    Type in the Address: 192.168.0.10
    Type in the Queue: hp5
    Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
    and find the driver for your HP LaserJet 5MP.
    Save it. Works like magic. ;-)
    If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
    Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
    Wireless laptop not printing
    Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
    Jan 20, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
    HP laserjet 1018 service
    Have you installed the new drivers for your HP?
    Personally, on all HP Printers, I use only HP products, mainly Jetdirect Print Servers, but you might try creating a TCP Port Printer (via your Printer Install Wizard) and use that. You only need to know the IPAddress of the DLink and the Drivers for the HP Printer.
    Dec 04, 2007 | D-Link DP 311U (DP-311U) Print Server
    Cant print from workstations
    Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
    Aug 10, 2007 | D-Link DP-301U (790069251979) Print Server
    D-Link Air Plus DP-G310 (dpg-310) Print Server Logo
    1,944 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
