Question about Hitachi Computers & Internet
Hitachi external usb storage drive comes up fine when turned on, but then after a few minutes "detaches" - then it spins back up and shows up - then after a few minutes detaches again. kind of comes and goes - this happened with 2 different drives on 2 different PCs so I'm guessing its the drive - thoughts?
    Scholar:
  • 47 Answers
I agree - it sounds like your drive is failing. I highly suggest backing up any important files on that drive before it loses them - I had a similar problem with an external USB drive and only managed to recover 80% of my files before it totally broke down. If it is still under warranty the manufacturer might replace it. If not, it's worth a few bucks in parts. :(
Posted on Jun 10, 2008
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
My hard drive is not being recognize
Jan 06, 2013 | Computers & Internet
I dropped Hitachi external drive...
If you have no backup and your drive is damaged, that is it, no data.
Plug the usb in with your drive, leave your computer looking for the drive. If windows, it may take some time. If Mac it won't be long. If neither can see it, the TOC is damaged and it will need a computer engineer to try and recover the drive.
May 28, 2017 | SimpleTech by Hitachi SimpleDrive Rev. 3...
Help! XP stopped recognizing my external hard drive. It has worked fine for two years and then suddenly: My Laptop no longer "dings" when I plug in the external hard drive. There are no unknown...
No question is silly dear, problems are there and we are in this site to help.
Yes, you mentioned that the said device works fine with your desktop, then it is probably not the problem with your device. You have also said that your tried formatting the os. Good.
Hope your pc, laptop and the memory device are disinfected with a good, licensed and updated antivirus.
Check, if Universal Serial Bus Controllers (corresponding to the nos. of total usb port present in the machine) are present and enabled both in the device manager and the bios as well and set to Hi-Speed if it is Full-Speed.
Well, have you tried formatting the memory stick/device? Format it and see if it works.
Next, please change the usb connectivity cable using/attached to the device and see.
Another thing while connecting an external storage device like ext-hdd. The external usb storage devices that gets connected with a usb cable, in some rare cases needs to be connected as a usb-master or usb-slave [you can see many external usb drives comes with a splitted or dual usb port connector cable, this is either for connecting two usb device or to connect as master when used as a single drive], therefore use such cable to connect and use alternated ports, and see which works.
Now, if all above fails, it then might be the problem with your external drive, i guess.
Best to seek help of your system admin/vendor.
Oct 16, 2011 | Microsoft Windows XP Professional
Hi there I just dropped my Hitachi external hard drive while transferring some files from my laptop to it. It was dropped from the height of a dining table. After I hooked it up to the laptop again, it...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 10, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Hitachi External Hard Drive 500 g where do i get the driver for it ?
This is what I get from Hitachi about the USB drives:
The External USB Storage and Portable USB Storage products do not need additional drivers to function in WinXP/2000/Vista, or the Mac system 9.2.2 or OSX. These operating systems already include the drivers needed for USB storage devices.
Looks like you don't need a driver. This is what I expected.
Feb 02, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
External drive problem
On the computer that is not working, goto:
Right click on My Computer > Click Manage < scroll to Device Manager, then Expland Universal Serial Bus Controllers, then Right Click USB Mass Storage Device and click Uninstall. You will then need to right click on Universal Serial Bus Controllers and Scan for Changes. Plug in the USB drive and it should show up.
Jul 10, 2009 | Hitachi Computers & Internet
Problem with Hitachi 1TB external hard drive
Most likely you just burnt up the adaptor. You can order another one from Hitachi.
The data is probably still intact on the drive itself.
You can connect it to your computer with an adapter that plugs into the drive itself and the usb port on your computer. It then shows up as a drive letter as normal.
You can buy these sata to usb adapters at most computer stores for around $25. Tiger has a nice selection:
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=sata%20to%20usb%20adapter
I would pick one with an external power supply. It also connects to your hd. The ends are keyed so you can't miss-plug them.
Or find a local computer tech (most have this cable in our toolkit) and he probably will copy your data in a few minutes for you.
Sep 04, 2008 | Hitachi 1TB External USB 2.0 Hard Drive
External Hard Drive not accessible
open your external drive and check for connections. the hd might be loose.
Mar 17, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
