Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
I need to fit a new door seal
This washing machine is leaking down the front of the door, so I am guessing we need a new seal. I don't really want to pay a small fortune for this, so am prepared to try and fix it myself. Can anyone give me pointers on how to accomplish this?
Many thanks
Charlotte
  • Charlotte8 Jun 12, 2008
    Thanks so much for this information! I'm going to give it a go - where do you suggest I buy the seal from?
    Cheers Charlotte
    Novelist:
    Champion:
  • 244 Answers
Easy fix love what you need to do is un-plug the washer now tak the 2screws from the back of the washer that holds the top(lid) in place now open the door and around the edge of the door seal there will be a spring wire pull this out so you can unattach the door seal totally from the washer front the seal will still be attached to the inner drum though now stand up and look down through the top of the washer down to the front were your door seal is still attached to the washer there will be another clamp with a screw on it undue the screw but you dont have to undue it totally though pull the clamp out through the front through the door seal now will come off the washer now just do these instructions backwards to re-fit the new door seal let me know how you go on or if you get into trouble doing the job peter
Posted on Jun 11, 2008
  • peter gittos
    peter gittos Jun 14, 2008
    sorry for just getting basck to u hun been busy best and cheapest place is the ebay type in hotpoint door-seal and it will bring all up cheapest price first let me know if u need anymore help with anything else peter
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
    Problem Solver:
  • 4 Answers
Posted on Jul 02, 2008
Water leak from front loading machine
at a guess i would say there is a cut in the rubber seal around the door sometimes its hard to spot it but if you pour a cup of water on the seal and see if the water comes down under the machine if so you wil need a repair man/woman it a hard job
Oct 14, 2014 | Maytag MHWE201YW Laundry : Front Load...
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
Water is leaking from the front somewhere. hoses and fittings were dry...so it's coming from the front.
the first thing to check is the door boot seal make sure there is no tears in the rubber seal.
then you may need to check the drain pump and hoses.
Dec 07, 2010 | GE WSXH208A Front Load Washer
Front seal leaking in my bosch exxcel 1200
This video will show you how to change a door seal on this bosch bosch exxcel 1200
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
LG Washer leak, small tear in door seal
Follow these steps to replace your door seal:
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Jul 04, 2009 | LG WD-1080FD Front Load Washer
Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Dec 22, 2008 | Neff W5340X0 Washer
Washing machine leaks
GE Profile stackable washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 29, 2008 | GE Profile WPXH214F
Fitting a new door seal
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal. And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks. appliance doctor
Feb 05, 2007 | Zanussi IZ161S Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
339 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
