Question about HP Compaq Evo n610c Notebook
Battery not charging
The comp says 103 charge circuit failure
the batt won't charge
themox81@hotmail.com
  • 3 more comments
  • deanwich Jun 10, 2008
    it dint work
    comp says -103 charge circuit failure
    09287
    f10=rom based set up
    fn keys don't seem to work
    the comp works with out the battery
    it don't charge when it is in
    the fn keys don't seem to work either
  • deanwich Jun 12, 2008
    do you mean f 10 button ?
    comp says f 10 =rom mode
  • deanwich Jun 14, 2008
    thanx alot you guys for trying
    any other suggestions ?
  • Anonymous Jun 28, 2008
    IT works for me
IT works for me. Thanks
Posted on Jun 28, 2008
  • 3 Answers
I would advise you to try this:
1......Make sure the unit is completely off.
2...........Hold down the "FN" key and turn the unit on with the main sliding Power switch and immediately start to tap the "F11" key.
3.............The unit will look likes it's shutting down. Let it do this three times.
This resets the CMOS. On first boot, the POST will check the RAM and inform you that changes have been made. Accept the changes.
This also resets all of the information in the BIOS to the defaults. If you have made changes (security passwords, asset numbers,etc.) enter the BIOS first and record all these settings so you can restore them afterwards.
Posted on Jun 10, 2008
  • jim griffin Jun 10, 2008
    battery dead? have you tried it with the battery out?
My jeep grand Cherokee lorado 1998 won't start. If
are the inside of the battery terms dirty,corroided? do you know if motor alt is charging batt? how long did it run when you put new batt in? if it lasted about two days, its proubly not charging, also make sure nothing is being left on draining batt down, to check that, leave batt nuhooked pos side over night.
Feb 19, 2013 | Cars & Trucks
Batteries run out fast
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 25, 2012 | Canon PowerShot A80 Digital Camera
Have New battery and Alternator, battery still won't stay charged.
Since you are having a new battery and alternator the charging circuit of the electronic charging unit is a possible suspect.
All what is required is to check the charging voltage when the engine is started, if there is no increment of voltage when the engine runs the alternator then the connection from the alternator must be checked. Check the output from alternator, check the relay box which contains the charging unit. It can be a failure of the rectification or the stabilising circuit, the unit must be replaced.
Sep 21, 2011 | 1993 Buick Park Avenue
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
I have a sony evo n600c and when it starts up its says 103 charge circuit fails does and the battary does not work i know i will need another battery but what i am asking is is the 103 charge circuit fails...
This error is commonly seen in Compaq laptops. Take out the battery,start the laptop with the adapter only and see if that error message pops up again and if not then it might be your battery.Usually battery life is 3yrs. Put the battery back again and see if the message pops up again. Try the battery on a different laptop. It could be the Voltage Converter Board...see service manual for the same or call Compaq service centre.
Jul 28, 2009 | Compaq Evo N600c Notebook
Mge nova avr 1250 problem
ups charged for 8 hrs .No alarms but on powerfail no output to connected device
Nov 15, 2008 | Computers & Internet
LOSSING CD DRIVER COMPAQ EVO N610C
The problem with your system is that the Battery you are using is Faulty is either the current voltage spoilt it or may be is an old age battery
What you will have to do is to get another Battery that you will first of all Charge it well before usage ok. nice
Sep 23, 2008 | Compaq Evo N610C Notebook
Battery installer
My compaq evo n610c have the following problem: "103 circuit charge failure" and use power AC only.
best regards
Sep 19, 2008 | Compaq Evo N610C Notebook
Original shape oakley thump
www.baterysplus.com
www.batteriesbatteriesbatteries.com comp usa staples
bestbuy circuit city radio shack <<< blah order direct from oakley and get quality
my spelling bad this morning bare with me i might not have spelled baterys right
Jun 02, 2008 | Oakley Thump MP3 Player
HP Compaq Evo n610c Notebook Logo
220 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
