Question about Whirlpool Washing Machines
My washing keeps coming out of the machine with tiny holes in, even brand new items
  • Richard
    Richard May 11, 2010
    Is this a Cabrio?
    Novelist:
    Champion:
  • 244 Answers
Check your inner drum there will more then likely be a small tear on the drum place your hand in the drum and move it around feeling every inch of the inside if you dont feel anything then it could be getting caught in the door seal
Posted on Jun 11, 2008
Why does my Whirlpool H2low washing machine smell bad inside?
Are you sure it's your washer or is there an awful sewage gas smell coming up your drain where your washer hose drains in.. I had this happen and I had to instal a U trap in the line the washer drained into.
Sep 09, 2014 | Washing Machines
Making tiny holes in clothes
Check drum and agitator for cracks or something that may be hooking the clothes.
May 09, 2009 | Washing Machines
Lent in waterhose
Lint is nothing more than broken fibers in the fabric. To minimize lint, make sure you don't overload the machine. Loosely load items to the top row of holes in the tub. With a full oad, select the highest water level and use the proper amount of detergant. If you have a two piece agitator, verify the upper section turns one way like a ratchet. This action keeps the load circulating so the same items are not at the lower section of the agitator thoughout the wash and rinse cycles.
Apr 27, 2009 | Washing Machines
Washing machine walks while spinning
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. in washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Dec 13, 2008 | Maytag Neptune Washer
Tiny Holes in My Cotton Shirts
If you have granite counter tops then they are ausing it - There is either a small chip in an area where you lean across a lot or your edges are too sharp ( usually with a bevel this happens). I had the same problem for 8 years! Recently put masking tape all the around the edges of my counter tops to test this. No new holes. Just paid a guy to come and smooth down the edges all the way around - expensive but the savings in therapy bills will be worth it- I had been driving myself crazy tring to figure it out and slowly eliminated all other suggestions. I read where one women just started wearing an apron and that solved it for her but I spend too much time in the kitchen for that.
Try the tape - it is a cheap (though not attractive) test. I left it on for a month to be sure. Make sure to check bathroom counters, laundry room ,etc.
Ann
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Tiny holes in clothes
We have the same problem. Look at the agitators inside the washer. We found strings and material there. Not sure what or if there is a fix bout I just saw the problem 2 days ago.
Aug 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
HOSE PARTS?
If you mean external hoses between tap and washing machine, and washing machine and waste drain to install the washer in place. Everywhere. even the local hardware store, those items are a standard size, thread, and diameter and fit all washers.
if you mean the click fit hose to a sink tap, with the waste water drain buldled in so the washer can remain portable
Sears has them as a to-order item and most parts stores will have a generic brand that will fit straight on, the screw fittings are standard.
Aug 08, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
ZWF1432W Zanussi Washing Machine
has the transit brackets been removed, these are bolts that secure the drum while its being moved, failing that this could be a call out under guarantee, the bolts and location of where they are etc are in the instruction leaflet and differ from machine to machine etc
Oct 03, 2007 | Washing Machines
LG WM2277H - OE error
yes,once you have disconected the power supply.open the filter hatch then undo the screw,this willennable you to remove the bottom plinth,unscrew the three screws that hold housing of pump,remove both the circ pump and the drain ,u will find offending item there
Jul 30, 2007 | LG WM2277H Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
