Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Blue hue has appeared on bottom right corner of screen. Is there a cost affective solution to this issue? If this requires an in-home service call. Please provide information for Pittsburgh, PA 15210. Thank you. Kurt
Sony announced that they would provide additonal service coverage for this problem. This service must be accomplished before 12/31/2008. The toll-free number is 888-649-7669. The link is http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655.
Posted on Jun 18, 2008
    Scholar:
  • 137 Answers
Hello stimka01,
let me just get straight to the point. Your lite engine is defective. There is no fixing it. You just need to replace it. The new engine will cost you about $700.00 and thats a friendly price. You can probably install it yourself. This engine is one of the less painful to install. You can contact me for assistant in installing the engine after you purchase it.
best regards
Posted on Jun 12, 2008
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
How can i adjust colors in konica c450
HI ganesh,
Instructions
    • 1Go to the Application screen on the LCD panel located on the printer and press on "Edit Color." Press on "Color Adjustment."
    • 2 If unhappy with the hue of your copy, press "hue." Look at the 'hue" screen and press the arrow keys in the direction you wish to change the color hue. Press "Sample Copy".
    • Sponsored Links
    • 3 Take a sheet of paper and place in the top left corner of the glass surface of the Bizhub. You will see that the area is marked "Sample Area" alongside the glass area. Press the "Start" button on top of the Bizhub.
    • 4 Wait for the Bizhub to produce a sample sheet. Look at the finished sample sheet -- there are six options showing three incremental "plus" hue options and the three incremental "negative" hue options. Select the one you like and press to confirm the required hue adjustment on the "Hue" screen. You have now calibrated your colors as desired.
Read more: http://www.ehow.com/how_7590176_calibrate-colors-konica-bizhub.html#ixzz316wHLgOK
May 08, 2014 | Office Equipment & Supplies
I have a blue oval hue in the middle of my screen, how to fix?
This problem is known as a defective Light Engine. The cost is usually 800.00 plus.
May 01, 2009 | Sony KDF-E42A10 42 in. LCD Television
A blue semi-circular hue on the bottom left of the screen
9 times out of 10 the Blue Polarizer heats up and discolors which causes that problem, all projector's have the same issue and have for years. My professional recommendation is get in touch with Sony, they have been extending the warranty's for this issue. If they won't the have a servicer replace the light engine of which is not cheap.
Jan 19, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
3LCD Projection TV 2.5 years old displaying blue hue/blobs
I would first try a new lamp. If the reflector portion of the lamp has any defects, it could show up this way as the light would not be uniform. The next possibility is a defective light engine. The engine portion if not field repairable and would need to be replaced. Try the lamp first and let us know what happens.
Dan
Jan 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDS-R50XBR1 has a yellow hue in the lower right hand corner of the screem
Hi JimmyDeps
If there is a yellow hue I would guess that this a LCD TV right ?
Which means that the blue LCD has gone and will have to be replaced.
May 13, 2008 | Sony BRAVIA SXRD HD Home Theater Projector
Bad light engine I think
I had the same sort of idea..bad color engine.Hitachi paid for upgraded replacement 'cause they had had so many similar problems with this model. My warrenty had expired so they did save me about $1200 but I was stuck with the labour cost approx $300...
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue hue on bottom of screen We have the same problem. A blue hue extending the bottom of the screen and now is working its way up the middle .
call SONY at 800 222 SONY and explain it to them and be prepared to have your TV fixed for free !!! the projection block is faulty do to outsourcing on that part for a limited number of tv's an mine was 1 of them , SOny took care of everything !!! good luck
Feb 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
On bottom of screen, sound like a bad lite engine. Average cost
$600. Part number A-1084-658-A
Best regards
Circuitcity
Dec 26, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony projection tv
you might have a couple of dry joints, and you might also have a bad PTC inside that degauses the screen when tv starts up. Please try another good tech for a service. Patrick
Aug 26, 2007 | Sony KP61XBR200 TV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
47 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
