Question about Hoover Nextra HNF 3167 Top Load Washer
Hoover washer dryer hnwf7167
Hi my washing machine will fill with water and empty but the drum will not go round we have checked the filter and the belt but they seem to be fine my warranty ran out 3 weeks ago and the retailer or the manufacture does not want to know. Have you got any idea what the problem might be.
Many thanks
  • tracyjw Jun 14, 2008
    It was my carbon brushes and my husband fixed it easily with your advise it has saved me from having to buying a new one.
    Thank you so much.
  • Anonymous Jan 08, 2009
    my hoover netxra hnf 6167 has a very similar problem, sometimes it will rotate, sometimes not, could this be same problem?
    Novelist:
    Champion:
  • 244 Answers
This will be your carbon brushes this will only cost £15 at the most pull your washer out now tip it back so u can get under it the carbon brushes are fitted on each side by 2 screws there are only 2 carbon brushes on your motor
Posted on Jun 11, 2008
  • peter gittos
    peter gittos Jun 14, 2008
    its ok hun sorry that im just getting back to u been busy and its my pleasure i would rather tell people the fix rather than they get ripped off by a shop peter
When my washer/dryer is turned off, why does the drum keep filling with water?
Turn the water off in the back of the washer where the hoses hook up...
Then check this tip out...
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Apr 25, 2010 | Hoover HW130M Front Load Washer / Dryer
Hoover performa 1100 ac110 not emptying
After syphoning water out of drum, remove and clean filter located at bottom front left of washer, if there is a screw in the filter cover, unscrew this first.
Remove filter by unscrewing anti-clockwise.
Feb 06, 2010 | Hoover Washing Machines
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Hotpoint ultima washer dryer
ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover Nextra HNF 3167 Top Load Washer Logo
235 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
