Question about GE 30 in. JP326 Electric Cooktop
GE electric cooktop
Unit is not receiving electricity - nothing comes on. Checked breaker box and everything looks okay. This is on the same breaker that the oven is on and it is working. Want to see if I can repair it myself instead of having someone out.
  • Anonymous Jul 12, 2008
    where i can find the fuse in ge cooktop
  • 161 Answers
Try looking at the junction box that it is connected to. Maybe one or more of the wires have burned off or come loose from the wire nuts. How many amps is the breaker? Most electric codes require separate circuits (Breakers) for each appliance. First turn off the breaker. There should be an outlet box of some kind on the wall or behind the cabinet. Follow the wire from the cooktop and see where it goes. Open it up and check if any wires are burnt or loose. If it was installed wrong I would change it. Most cooktops shouldn't be fused at more than 30 amps. Single ovens the same, double ovens up to 45 amps. The problem is if they used an old range outlet with 6 gauge wire and tried to connect both appliances to the same wire. This is hard to do without it coming loose.
Posted on Jun 29, 2008
Just installed replacement glass top (from GE,original) and get Codes SE on the timer touchpoint.
That error comes from the touchpad, if it got wet, something boiled over on it, it is shorted etc.
May 07, 2016 | GE Profile 36" Electric Induction Cooktop...
Electrical wiring
ones connecting to anther set of plugs red on postive top countuins sending power to next box in a chain
Jan 19, 2008 | Jenn-Air JED8430 Electric Cooktop
GE XL44 range - electric igniter for top burners not working.
Sounds like igniter problem. Did some one pull the electrical cord or has a fuse or breaker blown/ Things to check. Your igniter is run by electricity.
Dec 30, 2017 | GE Profile JGP636 Gas Cooktop
Radiant cooktop blew a fuse?
Call the service tech it;s under warranty and, this model is notorious for this fault
Apr 21, 2009 | General Electric 36 in. Profile PP962...
The cooktop does not come on
It sounds like the circuit breaker is kicked or the fuse is blown.
look in your electrical panel for the breaker and in the fuse box to see if the fuse is blown.
Feb 12, 2009 | GE 30 in. JP340 Electric Cooktop
My ge ceramic cooktop hot indicator light won't go out
I know that some people have mentioned that it looks like it's on, even when it's off. Depending on how the light hits it, it can look like it's glowing a bit. This would be normal.
Dec 27, 2008 | GE 30 in. JP340 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Loud Pop, blown Breaker
Pull the unit away from the wall and inspect from rear. However, if all is fine, perhaps you simply overloaded the circuit that once. Were you running any other appliances (overhead microwave) at the same time?
Mar 28, 2008 | GE 30 in. JP340 Electric Cooktop
GE JCP 930 Cooktop Wiring
These fuses are under counter? It should be wired to breaker box. Check specs in manual but i suspect a 30 or 40 amp breaker.
Nov 17, 2007 | Maytag MEC5430 Electric Cooktop
Open Questions:
GE 30 in. JP326 Electric Cooktop Logo
243 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
