Question about HP PSC 1610 All-In-One InkJet Printer
Error 0x031e4dd6798:lib_barracud How do i solve this error on my all-in-one HP printer6210 error 0x031e4dd6798:lib_barracud
  • 3 more comments
  • Topea Jun 10, 2008
    0x031e4dd6798:lib_barracudhow do i solve this problem
  • rmfrontini Jun 21, 2008
    I have this error, how resolve them please?
  • zexx0r Aug 14, 2008
    okay, the printer is not mine, I`m just someone who`s job is to fix this problem :) so ... if anyone knows how to do this... let me know:
    nidza.breaker@gmail.com
    thanks!
  • Anonymous Oct 02, 2008
    zz sdjkd
  • Anonymous Dec 04, 2008
    when i need to do alignement of carouche i see this error
2 Suggested Answers
  • 181 Answers
SOURCE: error msg below
its the main board error.that needs to be replaced.it will be very costly .
sometimes unplugging the printer for sometime and then replugging it helps.u can try that before taking any descesion.
Posted on Nov 13, 2008
Script: chrome://wrc/content/common/libs/jquery-1.5.2.js:3589
Script errors are common. The best thing to do is to go to the internet options and deselect the entry that says "warn me of script errors".
Though the errors will still be there you won't get the notice!
Jul 30, 2014 | Google Chrome
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
Sep 25, 2012 | Borland Turbo C++ 3.0 Full Version...
Since upgrading my Windows XP to Windows 7 I have experienced an error message on my HP 1610 (0x031e4dd6798:lib_barracud. How can I get this fixed. I loaded the old installation CD which is not compatible...
Hi, your printer should work fine with Windows 7 -- you just need to download the correct driver. You can find the Windows 7 driver for the PSC 1610 here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=390315&
Just choose your operating system and click Next to download the Windows 7 driver. (You should uninstall the Windows XP driver first, before installing the Windows 7 driver.)
Once you have the Windows 7 driver installed, your HP printer should work fine!
Nov 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Trying to repair windows xp on a Seagate Barracude 7200.7 160gb SATA HDD
Can you pleae be a little more explicit? What is the make & model of your computer? What kinds of repairs are you trying to do? What kinds of errors or symptoms are you experiencing?
Jan 19, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Error msg below
Nov 12, 2008 | HP PSC 1610 All-In-One InkJet Printer
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Error code wont initialize
The next step is to uninstall the driver and software for the printer and do a fresh install of the software. It sounds to me like your drivers have been corrupted. If this is the case reinstallation of the software and drivers will solve your problem.
If this does not work here is the tech support line for Your product: 1-800-474-6836
I hope this fixes your problem, Please do not forget to rate me if it does.
Thank You
George
Nov 16, 2007 | HP PSC 1610 All-In-One InkJet Printer
Error: 0x07a74dd61959:lib-barracu
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Jul 14, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
657 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
