Question about Motorola Mobility L6 Cellular Phone
Cannot reply or send any text messages, although I recieve them
I can phone out using my address book, and can dial numbers on the key pad, I can do everything else, but when I try to type a text message the phone freezes up and I cant do anything. I have to take the battery out to switch off. The phone is almost two years old, had it since new.
  • 1 more comment
  • cath cochrane Jun 10, 2008
    Thank you for your speedy reply, however, please forgive my stupidity, but I don't know how to do this, I don't even have a computer cable for my phone. I am not very phone literate. Can you assist?
  • Ashusahni Jun 11, 2008
    how Do Work Sync plz Tell Me ?
  • the kins Jun 12, 2008
    I have exactly the same problem - phone freezes when I try to text and I have to take battery out to switch off. Like Catluvva, I'm not too computer literate, so need someone to spell out a solution in easy steps!
    Brigadier General:
  • 7,752 Answers
The phone firmware may need reflashing
Posted on Jun 10, 2008
How to forward a text message I have recieved to other numbers in my contacts?
Welcome to FixYa!
Forwarding a text message varies in different models of Motorola Cellular phones.
I'm going to give you a generic answer since you have not stated the model# of your Motorola phone.
Open the text message that you want to forward. Go to Edit mode. Click edit then,
For some models, it will work this way: Go to the field where you input the recipients phone number. Input the recipients phone number or search from your phone book. Then press send.
For other models, it will work this way: Click send while in the edit mode. It will ask for the recipients phone number. Input the phone number or search from your phone phone book.
I hope this helps. Thank you for using FixYa. Have a great day. Jas247
May 19, 2011 | Motorola Cell Phones
One person within my contact list never recieves my texts
try just using her number instead of the contact u made ie just either remove the contact and then send her a text with the number she has correctly
Jun 05, 2010 | Google Android
Same as above. I cannot send or recieve text
u can change the sim or connection or go to message setting change the voice dial number of ur costumer service by asking to them they had its solution or update ur phone or reset all default settings
Mar 18, 2010 | RIM BlackBerry Storm 9530 Smartphone
I need to block text messages
if the text come from a 5-digit number then premium texts can be stoped just by replying with the word "Stop" or "cancel" u should get an immediate responce back to confirm. If not call srcv provider to place individual block from that company if our recieving from an email address or actual 10-digit number
Apr 03, 2009 | Motorola Mobility VU204 Cell Phone
Cant send texts but can recieve them
This is almost certainly a problem with your phone not having the correct Message Centre settings (have you ever used this phone with a different carrier?).
The Message Centre number can be found in Messaging/Settings/Text Message/Text Message Centre. You will probably need to check with your Service Provider to get the correct number, although you may find it on their website.
Mar 30, 2009 | LG KU990 Viewty
Cant recieve text messages on at&t motorola c168i
there are a few reasons that could be causing this.
1. You may have changed the message center routing number.
* Go to messages - options - message setup - text messages - profile - SMS settings(should be check marked, if not select activate) - Customize
* The message center number should be +13123149810(plus must be entered....hold 0 key for plus)
2. Text messaging pay per use has been taken off your account. dial 611 from your phone or 1-866-246-4852 (after hours call 866-801-3600) from another phone for customer service. request pay per use to be added to your phone, or purchase a messaging plan.
These should cover it. Make sure to power you r phone off and on after any changes.
Dec 21, 2008 | AT&T Motorola c168i Pay-As-You-Go Cell...
Motorola L6 does not send text messages
you should send it to a mobile service center close to you to have it done.
Jun 19, 2008 | Motorola Mobility L6 Cellular Phone
Txt messages
Error message 38 means there was some type of problem with the number to which you were texting. When sending a text message, make sure you are sending the message to a ten-digit mobile number (assuming you are in the US). If you're sending a text message to an entry you've saved to your address book, make sure that you stored the number with area code in your address book.
If all of that checks out, or if you've had no problems texting to this exact number before, you will want to place a call to customer service with your wireless service provider. They can look at message logs within their network to see what happened and why the attempt failed.
good luck
c.j.
Mar 26, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Problems with text messaging
Probably configuration problem. Make sure the center number is the one used by your service provider and set Reply via same center number to No.
Jan 07, 2008 | Nokia 6288 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
