Question about HP Designjet 110plus nr InkJet Printer
HP DesignJet 110 - will not move cutter after job is printed
Hi
Having trouble with paper roll feeder. Has been working fine, serviced printer (ie cleaned all paper feed tyres and cleaned sensors) but still can not get the paper to feed and stop when first fed into the printer AND when I did (once) the print job finished but the cutter did not move to cut the paper, just sat there.
I am guessing that a paper sensor is not working to tell the printer that paper is being feed, but which sensor.
I work on HP printers but not the DisignJet 110 plotters (used in a drawing office)
Any help ASAP would be great, as I am on site now !
Regards
Vince.
  • 4 more comments
  • Vince Coombs
    Vince Coombs Jun 10, 2008
    Thank you for your quick reply.
    I did not "touch" any sensors just used my puffer brush (no contact was made).
    But i like the option if all else fails of sending it back to HP for repair.
    i will check with the customer to see when they bought the printer and check with HP.
    Regards
    Vince
  • Vince Coombs
    Hi
    I will look into the firmware and see if it needs upgrading.
    In the mean time i will check/adj the feed ramp springs.
    Back soon.
    Regards
    Vince.
  • Vince Coombs
    Vince Coombs Jun 11, 2008
    Hi
    I have not found the firmware upgrade site yet ??
    Also I believe the problem lies with the paper roll feed device (Q1247A).
    There are 2x sensors on the unit you can take out the back of the printer and I think it may be one of these or the wiring back to the feed roller?
    Every thing else looks ok and works (ie prints ok from the paper tray)
    So, to sum up : when the paper roll if first put into the slot on the printer the printer does NOT bleep and feed in the paper roll, so the printer does not know that paper is ready to be feed (although I have pushed it into the slot until it stops)???
    Regards
    Vince.
  • Vince Coombs
    Hi
    Regards
    Vince.
  • Vince Coombs
    Vince Coombs Jun 13, 2008
    Still looking for some help with this one.
    Which sensor is it that tells the printer, that the paper is ready, for it to feed the roll into the printer and then bleep to say it is ready for use?
  • Vince Coombs
    I have made sure that they are using the printer correctly (they have been for 18 months - they tell me!)
    Genius:
  • 3,422 Answers
The cutter depends on the carriage to move from right to left; the carriage picks up the cutter cuts paper then returns the cutter, releases it returns to the right side of the printer. If you can see the carriage move to the cutter but then it doesn't latch onto the cutter, you may want to try removing the cutter then re-installing it, to see that it is correctly setup to cut. If you see only the paper move (but not the carriage) it is possible that your printer needs the firmware upgraded.
The next thing is that make sure not to tighten down the screws too much, since that would impede its ability to move. Once you re-seat it (several times) and fiddle with the screw tightness, it should work.
Goodluck,
Please don't forget to rate or accept the solution
Posted on Jun 13, 2008
    President:
  • 2,712 Answers
Try a hard reset first: Unplug the printer from AC source, and any other input device. Wait about 10 minutes and reconnect. Power on the printer and see if that helps. If not,you have a problem with either the sensors or the circuitry. Best call HP tech support for detailed analysis..
    Master:
  • 497 Answers
Http://www.freedompaper.com/s.nl/it.I/id.149/.f
All the best
Have a nice day!
tc
    Sergeant:
    Champion:
  • 230 Answers
The problem is with the feeding roller so do change that
    Genius:
  • 2,035 Answers
This is the problem with the feed roller they are not feeding the paper , this happens when then roller are completely fails or dust accumulates on the roller and sensors .
try this:
You have done the maintenance items, now check the soft item.
You are feeding the roll paper into the lower slot.
With a new roll of paper, it is easy to feed the paper into the rear manual feed slot.
to contact hp just click here:
Posted on Jun 11, 2008
  • 114 Answers
You probably shouldn't of touched any sensors. so if you go to www.hp.com see if you can get the printer RMA, which means you have to send them the printer, then they'll send you a brand new one via UPS for free. but they may charge S and H. Please rate my solution.
Posted on Jun 10, 2008
    Brigadier General:
  • 6,966 Answers
Initially, have you tried updating the the firmware through the HP maintenance portal? Alternately or additionally, pls try here. there would be a spring in the left side cover, and it strong and long spring that lifts the feed ramps and holds them against the pick cam. The spring force of the ramps against the cam creates too much drag for the engagement gear to overcome. Stretch the spring slightly.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jun 10, 2008
    Hi again, if you would try to stretch the spring, pls do so very very slightly.
  • 652 Answers
For paper cut, you should see the printer properties, there you can fine Auto Cut paper Check box or some thing like that. Make the correct setting, then it will work.
Thanks & Good Luck
Iqbal
HP designjet 130NR won't pick up paper from the tray.
paper tray lift clutch failure is likely the cause - common for this machine - repair with new feeder assy ordered whole from HP/ or Partsurfer
Jan 28, 2014 | HP DesignJet 130NR InkJet Printer
Paper cutter
You should try replacing the cutter assembly with a new one. They are rather inexpensive ($50) to purchase and easy to install.
The only other thing I can think would cause your problem is if something is stuck in the groove by the cutter guide that would cause it to disengage while cutting.
Jun 07, 2013 | HP DesignJet 500 InkJet Printer
HP Designjet 110plus tugging paper and compressing print
It could be a problem with the paper quality. Try different paper
May 30, 2013 | HP Designjet 110plus nr InkJet Printer
My HP1050c will print with the paper feed option fine, but when you try to load the roll feeder the rollers continue to roll backwards like it can't detect the end of the paper roll to size it. It seems...
I ran into this problem once on a Designjet 110 series and it turns out that there is indeed faulty sensors that cause this issue. Unfortunatley it required the replacement of one sensor that detects the start of a page. I checked HP and this issue is not noted for the 1050, but that only means it is not likely a common issue.Post a comment if you would like additional instructions on how to diagnose.
Mar 18, 2011 | HP DesignJet 1050c plus InkJet Printer
DesignJet 5500PS InkJet Printer WILL NOT CUT THE
check the media you have selected. if you have the wrong media selected, the cutter will not work.
Nov 03, 2009 | HP DesignJet 500ps InkJet Printer
Hp designjet 110 is not printing. paper is spooling then stops, retracts. orange error light is blinking. can't find users manual
check ur orange cartredge
& check ur orange printer head & clean ur printer head
ur problem is solve
because this problem is only cartredge & prinater head
Apr 22, 2009 | HP DesignJet 110 Plus InkJet Printer
Cutter Problem
the cutter has that bushing attached to act as a tire as it travels across the scan axis, these infrequently wear out and cause the carriage to basically drag the blade behind causing your uneven cut pattern, the cutter must be replaced. If you need direction on how to do so please contact me
Apr 16, 2008 | HP DesignJet 1050c InkJet Printer
Tears paper when trying to align
Sounds like the overdrive clutch is't working. try rolling the small rollers under the forward star wheels back and forth. if they turn both ways the clutch is bad (about $100) but tack heart, a couple drops of light oil (3 in one oil) usualy fixes it. go to http://sjdtrucking.com/hpplotters/index.htm I have the service manual posted for instuctions on how to get to it
Steve
Mar 06, 2008 | HP DesignJet 430 InkJet Printer
HP Designjet 110 plus nr print/feed problem
hmmm..sounds like a memory overload..shut down machine, let the memory clear, and maybe reinstall the print management software..print queue issues are almost always from overloading the memory for the printer..
on the feeder issue, check for paper caught in tray or path, and clean the rollers too.
check your computers warranty here 4 FREE
Feb 27, 2008 | HP Designjet 110plus nr InkJet Printer
HP Designjet 110plus nr InkJet Printer Logo
960 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
