Question about HP Compaq Presario V2000 Notebook
Lid Switch I have been told that it is a non replacable part so dosent have a part number. My laptop is not actualy a V2000 either not sure why they cant put the real number on the laptop. When ever I called HP they would tell me the real number it had US on the end of it.
Are you referring to the switch that turns off the LCD screen when the lid is closed?
The switch may be attached to the mother board, in which case, advance soldering skills may be needed.
Are you sure the switch is bad? I believe you can actually change the power settings to force the LCD to remain on, even with the lid closed. Perhaps that warrants a look.
Posted on Jun 14, 2008
I have a old Frigidaire stackable. My lid switch is bad. I can bypass it, but i was told the motor would burn out if left in the bypass position. I was told the manufacture doesn't make a switch f
if you can find any lid switch that will fit, use it, just make sure that the wires are the same size and you'll be fine. the switch only interrupts a sigle line to break the circuit when the lid is open. just like the light switch in your wall. So again if it fits and the wires are the right size do it. What is the model number of this washer?
Jun 09, 2012 | Frigidaire Washing Machines
Washing machine stops on rinse on all cycles
this could be a timer problem, or the cold water may be shut off.....if it is advancing to the rinse point but not filling, then there may be a problem with the fill valve also. You may want to check the lid switch too, just to be sure it is making contact.From what you are describing it sounds like the problem with your washer could either be the lid switch or no cold water. However there are a number of other possibilities. I would recommend checking the lid switch first. Open the lid & you should see the lid switch actuator mounted on the lid. This is the probe that pushes in on the lid switch as you close the washer lid. Next you can check the lid switch. The lid switch is hidden under the top of the washer. You will see a small opening where the plunger comes down at & activates the lid switch. You should hear the switch click as the lid is being closed. You can also use a small non-metallic probe to push in on the lid switch. If the lid switch is not responding, you will need to replace the lid switch.Next you will need to check & make sure the cold water is turned on. You may want to turn the water off & take the cold water fill hose off of the back of the washer. Use a bucket & turn the water back on to check the incoming water pressure. If the water pressure checks good & the washer is not filling for rinse, you will need to replace the water valve.If you have good cold water supply & the lid switch checks okay you will need to access the inside of the machine to make more checks. Be sure to disconnect electrical power before attempting any repairs. Please resubmit your question if you need further assistance.Good Luck
Oct 27, 2011 | Roper Washing Machines
V2000 mouse keypad dosent work plus some keys
I would check for spares on ebay. There are a lot of PC and Laptop breakers out there.
I suspect you will need a keyboard and a touch pad.
Hope you have luck with the spares.
Nov 22, 2010 | HP Compaq Presario V2000 Notebook
Will not agitate
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Jul 14, 2009 | Kenmore 24032\24036 Top Load Washer
The speakers on my laptop do not have any sound. I can hear sound only when I plug in headphones. Is there a way to switch speakers? I have a Compag Presario v2000
You could have damaged the sensor in the 3.5 mm headphone jack so your computer does not realize that there are no headphones plugged in. If thats is the case you will have to have the sound card replaced. Another problem could be that the driver is messed up if you recently updated drivers roll back the sound cards driver or update it. Finally you can simply hook up old non usb speakers that use the headphone jack.
Jan 08, 2009 | HP Compaq Presario V2000 Notebook
Compaq V2000 Display blacks out
sounds like the backlight has gone....test with an external monitor....if the external monitor works without any problems...the backlight has gone...better to get a professional to do this as its kind of fiddly and involves taking the screen apart
Dec 22, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 Screen went black
that's a video issue..most likely the lcd, since you have drive to external video connector?
got backup for that Presario?
Feb 18, 2008 | HP Compaq Presario V2000 Notebook
Using my notebook with a desktop flat screen
open display properties (windows xp), select power options (I believe within the appearance, or screensaver tab) power scheme settings - change settings for when you close the lid of your laptop.. set it to "do nothing"
Aug 26, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 "Doesn't turn ON"
1) Unplug the laptop. 2) Press and hold down the standby switch under the lid in the upper left hand side of the laptop while pressing down the power key. You should have full power startup now. Let me know if it worked..
Jan 27, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
381 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
