Tritton Technology TANGO Pro Digital Media Player Logo
Posted on Oct 29, 2010
How to convert an MP3 to an audio CD on Windows Media Player
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25
Points
6
Conversion softwares.....like total video convertor use it...
tip
How to transfer windows media player muisc to iTunes
You may have some music on Windows Media Player, and you want to add them into iTunes library for your new iPod or iPhone. Or you may want to move your iTunes bought music to Windows Media Player for portable devices such as Zen, Zune, Phone, Sansa, Archos, MP3/MP4 Player, etc. It’s easy to do that. And this guide will show the steps to do the job.
Part1. Transfer Windows Media Player music to iTunes
Step1. Open iTunes and select the File -- Add Folder to Library menu.
Step2. Browse to your Windows Media Player music folder. iTunes will ask you where your songs are located, which by default will be in your My Music folder on Windows XP, or in your Music folder on Vista.
Step3. Convert Windows Media Player songs to AAC format (.m4a). If you have files in WMA format, you will be prompted to convert those WMA files to AAC. This is a necessary step if you want those tracks available to play on your iPod or iPhone. If you have a large music library in WMA format, converting WMA to AAC may take a long time. Plan to do this at a time when you can leave your computer on and walk away to do something else for awhile. You can also import your WMA files as MP3 instead, which also allows them to work with your iPod, but makes them more portable if you buy something else in the future.
iTunes doesn't modify your original music files from Windows Media Player. It leaves those songs in their original location and makes copies in your iTunes music folder.
Part2. Transfer iTunes music to Windows Media Player
Because iTunes music has DRM protection, you can't easily import the music into Windows Media Player by drag and drop. There are two ways to transfer protected music from iTunes to Windows Media Player.
Method1. You can use iTunes to burn the music to a blank CD at first, then use Windows Media Player to rip the music CD, the DRM protection will be remove during the ripping process, then you can rip the CD into WMP library. This way is good for tranferring a few music. For large mount of music, it would take a really long time to transfer music.
Method2. If you don't have blank CD disk or you have many iTunes music need to transferred to windows media player. You can use DRM Media Converter. It can legally convert the protected iTunes music to non-protected MP3 music, then you can easily drag and drop the MP3 music into Windows Media Player.
Step1. Download and install the DRM Media Converter , the file size is about 7 MB. I have scaned it with Norton Virus protector and AVG spayware protector, it's safe without any warning.
Step2. Run the DRM Media Converter, Click Add to import iTunes music, which by default will be in My Music\iTunes\iTunes Music .Or you can run iTunes, click Edit -- Advanced Tab, there you will see where your iTunes media folder location.
Step3. Set the output audio format as "MP3 - MPEG Layer-3 Audio (*.mp3)"
Step4. Click Start to run the conversion, it will take a little bit time to finish the job, then click Browse to located your converted mp3 files, drag them into Windows Media Player, done.
on Feb 05, 2010 • Computers & Internet
Have poloroid mp3 player model 151, 2 gbs, it won't play audio books, files with AA extension. Audible.com site has no solution, i.e, doesn't list this device ed [email protected]
MP3 players play audio/music files that have mp3 file extension.
You need to convert the audio books to MP3 format.
If the audio books are on a CD, then you can use Windows Media player to RIP (convert) this to MP3 files.
2answers
How do you download music to an mp3 player from a cd?
Normal audio CD tracks should be converted to mp3 files onto the computer's hard drive, first.
This is called ripping or RIP function.
There are several programs that can RIP audio CD.
It is important to convert music into the correct bitrate for the player to match for playback. (192 kbps is good quality and often used)
You can use Windows Media Player 10 or 11 for conversion.
When you use WMP 10 or 11 and the player is detected in the program:
1. Tell the player were your music library is: setup your music library.
2. Create a playlist; make playlist name and add mp3 files to the list.
3. Synchronize the playlist with mp3 files to the player.
If the player cannot be detected in WMP 10 or 11, but only can be viewed as a removable disk in "My Computer" : use the "copy and paste" or "drag and drop" method to put mp3 files from the computer onto the player.
When needing more help, don't hesitate to write a comment in this reply.
When i download music to my mp3 player from my windows media player is says format error and I have media player 11
thats because media player is a WMA format the mp3 player needs to play songs in MP3 format ,what you can do is download a converter that converts WMA to MP3 and from now on start downloading music on MP3 format
1helpful
How do I put a cd onto my phillips go gear player?
On a Windows System, most GoGear players can be detected in either
Windows Media Player 10 or 11. Use the WMP version that matches your player.
Before putting music onto the player, audio should already be or must be converted into the correct format.
Most GoGear mp3 players support music in the format mp3 and wma: this is the extension of a compressed audio file: e.g. track1.mp3 or song2.wma, similar to a text file, that could bare the name textfile1.txt .
Consult the manual of your model player for the correct extension and bitrate: bitrate is the density of the bits used to make a compressed audio file.
In WMP 10 or 11 the function RIP can be used to convert an 'ordinary' audio CD into mp3 audio tracks.
Look in the player's manual or go to the site of Microsoft for more information about using Windows Media Player.
When needing more help from this side, just add a comment in this thread.
Hoe do I download music from a cd onto my mp3?
You don't give much information so I am going to assume you are using Windows XP. You can use Media Player within Windows to convert a CD to MP3 files. Just put the audio CD in your drive then Load Windows Media Player if it does not load automatically. This is found from the start button, Program files, Accessories, Entertainment, then Windows Media Player, You can then select the copy from CD option on the left side of the screen.
1helpful
2answers
How do i download youtube videos on my phillips gogear?
For getting videos from youtube you need to download youtube robot. Using Windows Media Player works well for syncing videos on mp3 players.
http://www.youtuberobot.com/
Computer
- This device also works with Windows 98 SE and Windows ME, apart from Windows 2000 and XP. Make sure all the critical updates are installed on your computer - To put songs from a regular audio CD to the MP3 Player, you would first need to convert the songs from the audio CD in MP3, WMA, Ogg or Audio ASF format. The songs in audio CDs are in CDA format. good luck
Top Tritton Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Tritton Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
