Question about Sony Playstation 3 (PS3) Console
Ip address timing out
I've got a similar problem to you, have you managed to sort it out or is it still playing up?
Cheers
Nic
  • akabaah Oct 10, 2008
    hi i hav the same problem, where can i find the ip address? also what do you put for proxy server and port number
  • Anonymous Nov 29, 2008
    i got a wired connection and when i try my adress is timed ouy
AS MY CONNECTION IS WIRED TRY THIS TURN ON COMP, TURN MODEM ON AT PLUG , THEN PRESS THE ON BUTTON, UNTIL ALL LIGHTS ARE ON, THEN PROCEED WITH CHECKING CONNECTIONS WITH PS3, IF IT DOESNT WORK TURN OFF MODEM ON WALL AND TRY AGAIN , MINE IS WORKING OK NOW
Posted on Oct 20, 2008
Cant set it up to internet via computer keeps coming up with ip address time out
Posted on Oct 12, 2008
    Problem Solver:
  • 32 Answers
Ur signal to low or u either have to type ur ip adress
Posted on Jul 05, 2008
I need to add an IP address to a Kocera 1320d that has been hooked up as a USB printer, how do i do this?
You can print a status page by pressing for 5 seconds the green button and see what IP address has the printer. Then you can modify it through your PC. The most important is that you have a NIC (network interfade card), because this printer (FS-1320D) comes from Kyocera without a NIC. Unless your printer is already intergrated with a NIC.
Aug 21, 2014 | Kyocera FS-1320D
IP address change needed on a AlphaServer DS10
First, identify the NIC you wish to change; use:
$ MC LANCP <ret>
> SHOW DEVICE
Next, use the menu driven utility "TCPIP$CONFIG", to set your desired IP address etc:
$ @TCPIP$CONFIG <ret>
Option 1 - core environment
Option 2 - Interfaces (then select your NIC or the IP Addr to change)
Option 2 - add/change a Primary address on *** (where *** is your NIC).
May 15, 2012 | Compaq AlphaServer DS10
Hiya, i'm having some problems with my Acer Travelmate 2410. I'm trying to get the LAN to work. When I press the button the front for wireless, I get a 'Wireless LAN disabled'. I've...
Well usually the wireless and the non-wireless NICs are two diffenerent cards, so I would be surprised that both cards are deffective at the same time... firs you need to verify if your DHCP supplies you with an IP address when connecting, try to notice the icone close to the clock (bottom write corner of the screen) if it has a small yellow dot moving sidewaise for a long time (wired or wireless) than your computer is not receiving any IP, check if you can connect to your network with an other computer to see if it works, if not than it's not the computer that has a problem but rather your DHCP server/router... if it does work than scan your non working computer with an antivirus it is probably infected...
Aug 08, 2011 | Acer Aspire 5050-3242 Notebook
Network key for ot 800
How do I configure my NIC with a static IP for use with a SpeedTouch Home?If you are using an Alcatel SpeedTouch Home (without a router), a PPPoE client such as NTS, WinPoet, or RASPPPoE, and are experiencing stalls and freezes while surfing or connected, it may be that your NIC is not configured correctly. You must set a Static IP on your NIC. If you have it incorrectly set for "Obtain IP automatically" it will be looking for a DHCP server that does not exist. During the time the NIC is searching for the DHCP server you will experience stalls and freezes. An incorrect NIC settings will also cause the PC to take a longer time to boot up.
This FAQ has two sections:
Section 1 - NIC Properties for Windows95/98/ME
Section 2 - NIC Properties for Windows2000/XP
bred.gifStep 1
Click on Start ->Settings ->Control Panel ->Network
bred.gifStep 2
Once at the Network Window scroll down and look for the first entry in the box marked Internet Protocol (TCP/IP) that is associated with your hardware ethernet card (ignore dialup, AOL, and VPN type bindings). Select the correct Internet Protocol (TCP/IP) entry and click PROPERTIES.
Actual screen shots may vary
bred.gifStep 3
Select the IP ADDRESS tab. Select Use the following IP address and enter 10.0.0.1 and 255.255.255.0 into IP address and subnet mask fields respectively. Do not click on OK yet.
bred.gifStep 4
Select the GATEWAY tab. Enter 10.0.0.138 into New Gateway field and click on Add. Click OK.
bred.gifStep 5
Close all windows and restart the PC.
Section 2 - NIC Properties for Winows2000/XP
bred.gifStep 1
Click on START -> SETTINGS -> CONTROL PANEL -> NETWORK CONNECTIONS. Right click on Local Area Connection and select Properties
bred.gifStep 2
On the General tab highlight Internet Protocol (TCP/IP) and click PROPERTIES.
bred.gifStep 3
Select the GENERAL tab. Select Use the following IP address and enter 10.0.0.1, 255.255.255.0, and 10.0.0.138 into IP address, Subnet mask, and Default gateway fields respectively. Click OK.
bred.gifStep 4
Nov 11, 2010 | Alcatel Speed Touch Home Modem
How do i get connected to another local computer with wire
you need either a "crossover" cable or both plugged into an ethernet switch, with network settings the same but i.p. addresses off by 1 digit. eg. 192.168.1.3 on computer "a" and 193.168.1.4 on computer "b".
Oct 25, 2009 | Computers & Internet
Just installed a D-Link DFE 530TX network adadpter into Dell Dimension 5000 desk top. Runnng Windows XP SP3. BT Home Hub 2.0 router. Even though broadband connection is fine to the router. The network...
Sounds like an IP address problem. Your IP address on both the NIC card (DFE 530) and the router have to be in the same address range. You can do this 2 ways. 1... Have your router hand out addresses automatically. Make sure DHCP is enabled and that you have at least one address available for it to give out. ie. 192.168.0.2 through 192.168.0.3. The first three number must be the same as the router. The other option is to manually set your IP address on your nic card to match the router. If the router is lets say 192.168.0.1 then you can assign 192.23.34.2 to your computer NIC. If you haven't been able to access your router then check your router manual to find out the default IP address and use the same number for your NIC changing only the last number. The largest number you can use is 255. Hope this helps.
Jul 12, 2009 | D-Link DFE-530TX+ Fast Ethernet PCI...
Connecting a Oki C5300N as a 2:nd printer in my Mac-network..
Good Day Joromich,
Sounds like your problem is just an IP address conflict. The easiest way to fix this is going to be through the front panel of the printer. You will need to configure the NIC to DHCP AUTO. This will allow the switch/router to configure the printer to the IP address schema your network is using.
You should also check you switch/router settings to ensure if you are using MAC address filtering (this has nothing to do with your Mac computer). The MAC address is the physical hardware address of any NIC device. It is the "permanent" device identifier that the manufacturer has assigned to the NIC. If your switch/router is configured to use MAC address filtering you will need to know this address. It will be a series of HEX values similar to this:
AE:02:4F:3B:55:2F
And is usually located on a sticker on the outside of the NIC adapter, if not you might need to remove the card from the printer to check it, however you should be able to obtain a NIC configuration page from the printer through the control panel. If you are using this additional level of network security (helps to prevent rogue devices from attaching to the network), you will need to add the MAC address to the switch/router filtering table. Most home network users do not use this additional layering of security, but when using wireless access points/routers, every extra bit of network security helps.
Once you have reconfigured the printer for you network IP schema through the use of DHCP, the network should now see the device. If you are configuring your printer drivers to print to the IP address of the device, you should disable the DHCP AUTO setting once everything is working. Otherwise the switch/router will replace the printer IP address once the lease is expired then causing your printer not to be accessible again.
Once the switch/router has provided the new printer with an IP address, you will be able to access the internal web page of the printer through your Internet browser. At this point you can then change the IP address configuration to DHCP OFF. This will prevent the printer NIC from making an IP address request and keep the IP address that has been assigned as a STATIC address.
Configuring the printer driver on the Mac is easy, once the device has been added to the network, the Mac Add Printer Utility will see the IP address of the printer and you can use this to print directly to it rather than using AppleTalk. As for problem of not having the orignal install CD, not a problem as the printer is listed within the Mac OS printer table. If you want to use the Oki OEM driver follow the link listed here:
http://my.okidata.com/pp-C5300n.nsf/openingdrivermenu?OpenFrameSet
Select the one you want and install it as usual. Hope this helps get you going.
Cheers, Happy New Year!
Keith
USA
Dec 26, 2008 | OKI C5300n Led Printer
WE use the lanfax option on our machine. Can anyone tell me how to change the location of the address book being saved. We have a network and it would benefit all if it were on the file server, not our...
type the IP address of you machine into Internet Explorer (any browser) that is on the same network as the machine,and press Enter,
it should take you to the NIC Page. At this nic page is where all your Network setting/ Fax Etc can be set.
Most Lexmarks with touch screens have the IP address of the machine at the top left side of the screen.. something similar too 192.168.1.150
Oct 27, 2008 | Ricoh Office Equipment & Supplies
Help
hi there,
if your computer has an ip address starting from 169.xxx.xxx.xxx then that is an invalid ip address... refer to computer vendor for another nic card.
Your ip address can be found by accessing the command prompt..
eg in XP
Start> Run> type in the run box "cmd" in the black dos window type in "ipconfig" press enter.
this will give out ip address, subnet mask and the defualt gateway.
Sep 24, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Can't assign ip configuration to NAS 208
Probably the NAS got the same IP address of the router/switch. Something like 192.168.1.1. Try changing your router default IP address to 192.168.1.3. Look for the NAS now.
Dec 22, 2007 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
110 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
