Question about Gateway GT5028 PC Desktop
No display Unit powers on, fans and hard drive responds but no display, ellow led for hard drive stays on for about 30 sec then goes out,monitor checks ok separately. 5v&12v are ok on hard drive. This is a all in one motherboard, intel d 845
  • stymieblue Jul 25, 2008
    I have the same exact problem. have tried to dc the CMOS batterey but there is some special tool needed to take the batterey out.
    I dont have the pc knowledge of how to dc the processor from the mobo so I cant try your solution. Please help
    Blue
    Scholar:
  • 107 Answers
Hi ,
this can be problem with CMOS ,reset CMOS by jumper or disconnecting CMOS battery .after this still problem with display please disconnect Processor from motherboard get cpu on without processor for 2 min .& after that cut off power assambled it as it is with processor & cheak it out
Display will come
If this information is useful for you please rate me ............
Posted on Jun 10, 2008
Acer Aspire 5610 wont start
Trying doing a Hardreset
Remove the adaptor and Battery and press the Power for about 30 secs
Dec 21, 2013 | Acer Aspire 5610-4648 Notebook
Tip
How to trouble shoot no display problem in PC
Mostly the prolem comes with PCs is no display. When such situation comes we can try following DIY and 90% the faulty part could be diagnosed:
1.Unplug the VGA cable of the monutor and if monitor shows some message (check signal cable) monitor is ok
2.First check for the power whether LEDs are blinking?If yes power unit is fine.
3.Check for the responses of the kwyboard LEDs, if after switching on LEDs are blinking processor is ok otherwise there is some issue with Processor.(Note it might not blink if the mainboard is burned)
4.Try to press num lock key if the LED is responding most probably this is the issue with RAM otherwise with Mainboard.
Thanks
on Dec 08, 2009 | Computers & Internet
Pc not booting
If you hear the CPU fan turn on that doesn't mean the CPU itself is working. It can be only that the motherboard is getting power. Check all your connections such as monitor and peripherals and re-connect them. If you still don't get P.O.S.T. or ANY letters or boot options on your screen then your CPU is dead. (unless your monitor is bad)
Another easy diagnostic is using your ears. For example the pitch sound of the fan in some motherboards tends to lower and then increase because it's reading of the hard drive. This means your CPU is ok but either your graphics connection is bad or your monitor is.
Apr 22, 2012 | Intel Motherboard
Unit starts ok then any where from 30 sec to 1 minute the screen goes black.power light good. opened unit capacitors good .if u put a flashlight by it u see the image. Is it hard to cnange the backlight...
hi,
Before going to replace CCFL check the inverter of the CCFL. Normally the inverter get faulty. There is possibility that the winding of the high voltage transformer get shorted or its driver transistor may get faulty. check the same
ok
Apr 15, 2011 | Acer P191WBD LCD Monitor
Acer 5610 cracked LCD..tried hooking it up to a external monitor, but all it does is Pwr up..no dispaly on external....fan goes on for about 30 sec. 3 led light up and stay on (pwr button, pwr indicator...
You may have to unplug the cracked display from the motherboard first before using the external display.Also check in the bios and make sure its set to CRT or for external display.If the keyboard has a key for switching displays try it with the FN key pressed.If that doesn't work you may have a damaged video card.
Oct 04, 2010 | Acer Aspire One PC Notebook
When I turn my V6000 on, I have power lights and the fan starts for 5 secs then shuts off. Nothing appears on the screen!
Sorry to hear about your V6000 problems.
If this problem has just started and all was OK before this happened.!
1. Remove all media from drives.
2. Remove battery and A/C power input.
3. Flip unit over and remove the memory.
4. Disconnect the CMOS battery.
5. Remove the Hard Drive.
6. Flip unit over and Press the Start Button for 30 seconds.
7. Flip unit over again and re-install the Hard Drive, Memory and last, the CMOS battery.
Note ...
8. Reconnect the unit to the A/C input supply voltage.
Leave the battery out for NOW !.
Flip unit and try to start with the Touch Pad Led's. This should bring up Quick Play.
If your unit starts and you here several beeps,
Don’t worry, !! You should be able to access the BIOS screen. You can reset your date and time.
If you are still not able to start unit, drop me a email and I will try some other ideas.
Hope this works for you. !!
Try it, It may work !!
John Ray
john@johnrraycomputer.com
Readers please rate your information, even if you disagree, it shows the technician, you care enough to respond.
Thanks.
Jul 09, 2009 | HP Compaq Presario V6000T 15.4" Notebook...
Not booting
Check your monitor,if it is running fine.Switch off your pc and monitor both.Switch on again.If u are not getting any display on screen ,u may need to repair your monitor.in between press on capslock or numsluck key.If keys are giving lights then 100% it is a monitor problem.
Jul 21, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
No display on LCD monitor
hi ,
Display will come
Jun 09, 2008 | Gateway GT5028 PC Desktop
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Gateway GT5028 PC Desktop Logo
135 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
