Question about Magellan eXplorist 500 GPS Receiver
Help Explorist 500 jammed (locked up) wont even turn off
Hi can anybody help solve this it happened after being connected up to my PC.
thanks from David
  • David1966 Jun 10, 2008
    My explorist 500 is on and stuck in the communications mode after being plugged into my PC, it won't do anything - do I just let the battery run flat and try tomorrow?
    Problem Solver:
To speed things up a bit with frozen Explorists, you can undo the battery cover and pull out the battery then replace and start again. I have had to do this many times.
Posted on Jun 11, 2008
To power down the unit
press menu then toggle center button left right left right left
then enter 10 and press center button.
Posted on Jun 26, 2008
My explorist Gc unit...on start up is looking for an active tracking file which is missing. I have a copy on my desktop. How can I get it back into the unit?
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
If you already have the file ..just rename it like I said ..and copy it ..using the sd card in the reader...Than if it is not functional ..just reset it ..and reload the file the proper way by reloading maps..
Aug 28, 2011 | Magellan eXplorist 500 GPS Receiver
Magellan Explorist 500
The necessary map software is not installed - did you buy the unit with software?
Mar 19, 2008 | Magellan eXplorist 500 GPS Receiver
Hi Guys: On turning on my explorist 400 a message appears. UNIT CURRENTLEY CONTAINS NO MAPS! INITIATING MAP UPLOAD This message wont go away, and all buttons refuse to work. The only way I can turn it off...
Jeff, I had the same problem with my explorist 500. Your unit lost the "BASEMAP.MGI " file. You will need to get a copy of that file. Then install it.
Try this site http://imhz.com/2006/05/my-explorist-is-screwed.html
(I would recomend all explorist GPS owners copy and save that file and store it in a safe place. I have mine on a thumb drive).
Dec 05, 2009 | Magellan eXplorist 400 GPS Receiver
Error Message on Explorist 500
With you 500 turned off press nav + power; then change the numbers 00 in 95 by using the joystick and and then press the joystick itself; accept what proposed.
after turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. if necessary, in usb file transfer mode, reload the basemap in the directory background maps
Jun 10, 2008 | Magellan eXplorist 500 GPS Receiver
Magellan
Mar 28, 2008 | Magellan eXplorist 210 GPS Receiver
Unit Map
Feb 02, 2008 | Magellan eXplorist 500 GPS Receiver
Fault mesage on screen when first strat magellan 500
Sep 04, 2007 | Magellan eXplorist 500 GPS Receiver
SD and explorist 500
Have you tried reloading your SD card with whatever data you have on there? Is it reading the SD card other then the odd behavior? -Daniel
Jan 07, 2007 | Magellan eXplorist 500 GPS Receiver
Magellan eXplorist 500 GPS Receiver Logo
355 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
