Question about Samsung NV10 Digital Camera
I have a samsung L100 and it seems frozen and won't turn off. The digital zoom won't retract and the LCD screen won't turn on.
  • 5 more comments
  • claireafraid Jul 24, 2008
    the same thing is wrong with my camera. The lens won't close and the screen is blank, and in order to turn it off i have to take out the battery.
  • heatherwv Oct 17, 2008
    I have the same problem! The camera is only a couple of months old and its totally useless now! Even if its fully charged, when you turn it on, the blue power light comes on, the lens opens, its beeps two or three times, the lens closes and the camera locks up - with the power light still on. Nothing comes up on the LCD screen and the only way to turn it off is the take the battery out. It used to do this maybe one out of every five times I turned it on. Now it does it everytime and the camera is useless!!!! Any ideas how to fix it?
  • Anonymous Dec 09, 2008
    omg...i have the same problem! really no idea wad to do with it to make it back to normal..i tink the only way is bring it to the service center.
  • Anonymous Jan 08, 2009
    blank screen, lens stays open, buttons do nothing, remove battery to turn off,
    repeat
    blank screen, buttons do nothing, lens stays open, remove battery, repeat
  • Anonymous Jan 17, 2009
    my screen wont come on and the power only lights up
  • kanwardeep May 18, 2009
    i have a samsung L100 and it seems frozen and won't turn off. The digital zoom won't retract and the LCD screen won't turn on.
I hav the exact same problem
Posted on Aug 21, 2008
It's getting replaced for a new camera.
Posted on Jun 11, 2008
I have a similar problem I turn the camera on and it wont stay on it turns off and beeps. Did you find any solutions to your problem?
Posted on Nov 19, 2008
My wb 210 got wet and now the zoom lens wont retract.
Unfortunately that isn't repairable. The most likely reason as to why the lens won't retract is because the water fried its circuit board and that is a costly repair.
Jul 26, 2011 | Samsung WB210 Digital Camera
Samsung L100 digital camera beep problem
If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work.
If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
Hope this advice helps!
Aug 04, 2009 | Samsung L100 Digital Camera
Screen not working
probably more than the camera is worth LCD screens are expensive
Jul 31, 2009 | Samsung L100 Digital Camera
All of a sudden became blurry when viewing through lcd screen and the pictures are blurry when downloaded on the computer
hi..
You can try a different memory card, but I don't think the problem is memory card, if pictures look scrambled, and colors and brightness are not uniform, that is either a problem with CCD sensor (optic sensor that takes the picture), or logic board.
In either case, this is not an easy repair.
Reset the camera to default settings from camera menu, and try a different memory card, but the camera will probably need to be sent in for repairs...
thank u
rate me!!
Jul 28, 2009 | Samsung L100 Digital Camera
Samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
Mar 30, 2009 | Samsung L100 Digital Camera
Unable to download pics on my Samsung L100
have you check if you are using the usb cable or the av cable. the camera will not show anything on the screen if you are using the av cable and connect the camera to your computer.
Jan 11, 2009 | Samsung L100 Digital Camera
Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Oct 30, 2008 | Olympus SP-570UZ Digital Camera
Samsung NV10 Digital Camera Logo
444 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
