Question about GE Dishwashers
Have a GLD6500L00CC dishwasher. after the completion of any cycle there is a lot of water standing in bottom.It is understood that there should be a little water to keep the seal lubricated but the level is as high as the brackets supporting the heating element. The manual refers to running the discharge hose high referring to the installation instructions. The installer did not leave any install instructions only the Operating manual. There is no air gap installed. Where do you go to get a parts break down showing the actual location?
  • rischaaf Jun 10, 2008
    What is the purpose of running the drain hose high? Is it to prevent waste water from the sink backing into the dishwasher? I could not find a parts break down of all parts on this washer or a repair manual at that web site.
  • rischaaf Jun 11, 2008
    I do appreciate the help, but when I give you the model #, You should be able to tell me that there is a pump used only for drain. To get to the inlet of this pump is not very easy, but it can be explained. All you did was to give out a lot of generic things to look for.
    The problem with the drain was too much dry detergant and it was in the sump. The major problem was how to get into the sump. I figured it out no thanks to you! When I signed on to this site, it was my understanding it was to be a GE service person. Again if only you would have given me a parts break down & how these parts are connected would have done wonders.
    Everything you told me was known by me prior to asking for advice.
  • 413 Answers
The drain line may be partially clogged. You will find manuals here:
http://www.geappliances.com/
Posted on Jun 10, 2008
  • Richard
    Richard Jun 10, 2008
    The purpose is two fold:
    1. To prevent waste water from sink reentering dishwasher. Most DW have a check valve to prevent this.
    2. Grease and other sediments will collect in the drain hose, and over time begin restricting water flow. All DW draining is a timed event, therefore the pump will operate for a specific length of time then stop. If the drain hose becomes restricted, there will be water remaining in the DW at the end of the drain period.
    Brigadier General:
  • 6,966 Answers
Hi rischaaf,
It could either be the filter (most likely), the drain pump (likely) or the drain hose/tube (least likely).
Normally, there would a filter somewhere at the bottom of your dishwasher with the primary function of keeping large particles of food and foreign objects away from the impeller/pump. Most current dishwashers have self-cleaning filters and therefore regular cleaning is no longer a concern. However, some other dishwashers need to have the filter manually removed and cleaned regularly or as even in your case. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher and may cause the problem as you have described.
To check the filter and/or the drain pump, the bottom has to be exposed, the filter/pump located and cleaned.
There are pages online with illustrative description and detailed procedures on how to go about this. Perhaps you can try referencing here and/or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Water standing in tub
If there is a lot of water sitting inside the applicance, it's possible that the high water float switch has been activated and is preventing the dishwasher from running. Open the door, remove the bottom rack, dip as much water out of the bottom as possible with a shallow ladle or even tupperware container. When that is accomplished, shut the door and try to run a drain cycle. If the unit won't start, you may have to remove more water. You don't have to have the rack in place to run the drain cycle.
Jul 09, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwasher not completely draining
Make sure the drain screen is not clogged at the bottom of the dishwasher or that you water drianline is not pinched or clogged behund the dish washer. if you are confidant in doing this you may be able to troubleshoot it. It possibly could be a water pump issue too.
May 16, 2010 | Dishwashers
Standing water in dishwasher
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
Sep 20, 2009 | Tappan Dishwashers
Draining after completion of cycle
Miele dishwashers are typical not to drain all of the water. It is the way the siphoning system is designed. You will always have a bit of standing water after cycle completion but should not be above the bottom filter. You can manually drain the dishwasher by selecting any cycle and letting it run for 30 seconds and then turn the dishwasher off. Hope this helps
Sep 14, 2009 | Dishwashers
Soap suds and some water not draining out of washer after cycle is complete
if you read the manual, it states that this is normal. so dont let this bother you
May 05, 2009 | Danby DDW496W Free-Standing Dishwasher
I have a GE PDW 8200 Dishwasher and there is standing water in the bottom of the tube. Why is there standing water after a complete cycle?
If it is older, the pump may not be draining the machine completely. The impellers, which is what acually moves the water could be clogged with yuck and could be cleaned if you can take the machine apart. If you call the repairman, he will likely replace the pump and motor.
Feb 24, 2009 | GE 24 in. Profile PDW7800 Built-in...
Frigidaire Model FDB2810ldc0 s/n:TH43526319
Dishwasher is leaking water from underneath during the rinse cycle and a small drip during the wash cycle
Sep 22, 2008 | Dishwashers
Not draining completely
always going to be some water left inside your d/w, cant pump it all out as long as its under the grate and not filling entire floor of unit i wouldnt worry, before each cycle its going to dicharge standing water anyway
Feb 23, 2008 | Admiral 18 in. DWCA500AA Free-standing...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher--water in bottom -end of cycle.
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Feb 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
123 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Ned Halaweh
Ned Halaweh
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
