Question about Gaggia Syncrony Espresso Machine
Goes into 'Self Test' after grinding the beans or even using the pre-ground mode
Hi, all. I'll appreciate your advise on this problem. It suddenly started to show this after more than 6 years usage. The machine was cleaned and de-scaled regularly even I have been using water softener at my house.
The symptom is as follows;
1. After selecting one of the three size coffee, the machine will grind the beans.
2. As soon as the grinding operation finishes, you will hear a few clicking sounds (which is normal) and the brewer mechanism is trying to move.
3. At this point, the display shows 'SELF TEST' and the brewer mechanism just go back to normal mode without brewing any fluid at all.
4. This happens regardless of the selected size of the coffee.
5. It was the same issue even when I used the pre-grounded coffee mode.
6. After this issue, if you open the side door, you can see lots of grounded coffee inside the dreck drawer and the bottom area of brewer mechanism.
Thank you for your help in advance.
    Sergeant:
  • Gaggia Expert
  • 223 Answers
You have a power control board(PCB) problem. The machine is restarting while trying to make coffee which would be like you turning the power off then on again. The only way to correct this would be to change the board.
If you would like to order the board you can do so by contacting us at www.cerinicoffee.com
Gaggia Parts and Cleaning supplies from www.CeriniCoffee.com
Posted on Jun 11, 2008
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
The problem is when I use pre ground coffee beans. The water doesn't run through. It comes over the top and the grounds get in the coffee. I buy them that way because they mark them down half price. I
There are whole coffee beans, and there are ground coffee beans, but there is no such thing as "pre-ground" coffee beans because you wouldn't want the beans to be ground AFTER making coffee.
If you have a problem using "pre-ground" beans, then STOP using pre-ground beans and grind them yourself.
I hope this helps.
Randy
Dec 01, 2012 | Coffee Makers & Espresso Machines
I put beans in where the grinds should go. help!?
Hi
Open the door and remove the drip tray. Then remove the brew unit and empty the beans. Make sure that you get all the beans. Check the brew unit thoroughly. Then put everything back. Try the pre ground button but don't put anything in the brew unit then push the medium coffee button. That will run the machine through a brew cycle and if it works OK then you set to go.
Dec 30, 2009 | Saeco Incanto Classic Espresso Machine
I can't remember where to put the ground coffee. Is it in the same place as the beans but with the grind off?
No, ground coffee goes directly in the filter.
Fill the water to desired cups, and turn grinder off.
Thanks for using Fixya - a FixYa rating is appreciated for answering your FREE question.
Jun 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Heat
Hey Nashville,
I have a few suggestions/questions for you. I've had the Innova(Ascaso) Dream for several years now and use it at least twice daily. I would trust your own senses before sweating the gauges too much. If you're really worried about it being a temperature problem, my first question is whether or not the espresso is actually hot when it comes out.
But my best guess is honestly your beans and grinder (or lack thereof). The problem with using pre-ground beans is that even on the day you open the can, they won't be nearly as fresh as truly fresh ground beans you grind yourself. And the problem gets dramatically worse every day after they are opened.
The key to a thick, crema-laden espresso is very fresh beans that you grind right before making your espresso. You can certainly confirm that the machine is working with any old coffee grinder and a bag of *really* fresh beans from a local roaster.
You really need all the oils that come with really fresh-roasted and fresh-ground beans. And the beans really need to be ground very fine for espresso.
I keep a can of pre-ground Illy decaf beans around for the rare occasions I need to make a decaf, and it's like night a day between that and what I drink daily.
If you try the fresh beans and grind them yourself and can see the obvious difference, then you may want to invest in a good-quality burr grinder (as opposed to the spinning blade kind that most folks use for drip coffee). The reason is that with a burr grinder you can get consistently-sized particles every time. So once you get the setting right on your grinder you can keep pumping out the shots time after time. With a rotary blade grinder you get some big pieces, some little pieces and the water flows through too easily -- or you grind it longer and (1) burn the beans from the heat, and (2) end up with some particles that are just too small -- essentially dust, that will actually clog the process.
So, my best suggestion would be to find a local cafe/roaster and buy a half a pound of beans from them and grind yourself. If you don't have a grinder or want to eliminate a variable, ask them to grind it for you for an espresso machine.
Again, if you can see the difference (and I think you will), then you can consider getting yourself a good grinder.
Tony
Jan 03, 2009 | Ascaso Dream Espresso Machine
Spinning but not grinding
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Dec 08, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Gaggia Syncrony Espresso Machine Logo
167 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
