Question about Nova Development Computers & Internet
Visat up date for Drive Erase Pro by Nova
UPgrade to Vista for Drive Erase Pro
  • 981 Answers
Vista is going to get a new filesystem soon, so by switching to that you should have your work cut out for you. Alternately, you can use drive encryption (there's a clear winner, and it's free software) and certainly accomplish what Drive Erase Pro did.
The most direct way to erase whole drives is using the maker's utilities, though; go to Seagate, Hitachi etc. and download their drive test etc. utilities. One of the options is erase!
Hey, try to write complete sentences when you write.
Posted on Jun 11, 2008
Should I remove Windows Vista on my Compaq Presario Laptop? It is installed as OE but I amm told Microsoft does not support it anymore
For the past few upgrade cycles I have upgraded by purchasing the best value new computers with the OS installed. I connect the old computers to the new via a home network. The newest has Win-7 and is much faster, however, the learning curve is steep getting all the old stuff to work. So for some stuff I still rely on the older machine. This has given me the best results.I still use Vista and XP, but if you feel compelled to upgrade do to security reason I would follow the following outline.
  1. Back up on an external USB drive all important documents. You must do this if not Murphy's rules will apply and it can be a train wreck!!
  2. Down load Acronis from Western Digital website. Make a Boot disk.
  3. Create a clone copy of your master C:/ drive on an external USB drive.
  4. Purchase a same or larger internal PC master C: drive "It must be a Western Digital for the free version of Acronis to work"
  5. Replace current drive with new.
  6. Using Acronis boot disk boot up and connect USB drive
  7. Clone new drive from USB with vista OS using the Acronis boot disk and confirm all is well
  8. You now have a way to go back. Your original drive still has the Vista OS with all your Junk and the new drive should have the same.
  9. Using the new drive go to the Microsoft website and go for OS seven. Keep your clone copy of the vista OS on the USB drive in case the seven blows-up during install.
  10. Retain the original C: drive with the vista OS in case you get into difficulty with the new drive.(mark the drive with date etc)
I have successfully done this for computers and keep a drive loaded with a known good OS for the day it all goes bad.
Sync-toy is the backup program that I use to keep everything up to date.
Hope this helps?
Mar 09, 2016 | Compaq Presario C700 Series Laptop...
Invoices and estimates pro for window 8.1 64 bit
Unfortunately windows installs are a total jailbreak sometimes. the problem might be with the windows install, not the apps. Try repairing winndows. Put the windows disk in the drive and boot the system. There should be a repair option. Also, try the system file checker, sfc.exe:
Start a cmd prompt as administrator and type in:
sfc /scannow<enter>
You'll need the install disk in the drive for this. If that doesn't work, you'll probably need to reinstall windows from scratch. That sucks, but windows sucks, so you're stuck. After the install, run windows update until it says you're up to date and then install the problematic software first.
May 28, 2014 | Nova Development Invoices & Estimates Pro...
I am running Windows XP, and have been using Nova's Art Explosion Publisher Pro 2.0. However, I recently had to reinstall operating system and all software and now I cannot get my system to read the first...
hi dontwakeme
Nova Development Art Explosion Publisher Pro 2.0 only running on windows 98/2000/me and XP
what is your system operation you use now?
if vista or 7, you need higher version of Nova Development Art Explosion Publisher Pro
Mar 20, 2011 | Nova Development Art Explosion Publisher...
My Art Explosion Greeting Card Deluxe Factory 2 software will not work on my Toshiba Satellite A200 laptop. I am using Windows Vista. Please can you advise?
Unfortunately the Windows OS has changed significantly since that software was released. Nova Developement now has the Greeting Card Factory Deluxe version 8 for XP/Vista/7.
If you have the 64-bit Vista, you may not be able to get the old software to work and need the upgrade or a virtual computer with an older Windows OS (see below). To check your OS version, click Start > Control Panel > System and Security > System .
You can try running the program in the compatibility mode - this will work best with software for XP not Win95-NT. Right click on the installer and select Properties. Go to the Compatibility tab and choose Run this program as compatible with (an older version of Windows). Click on the check box and use the drop-down menu to select the older OS. Save the change by clicking apply then close the window. Right click again on the installer and choose Run as Administrator.
If the program installs, do the same compatibility steps for the program's exe file itself. (You don't need to run as administrator though.)
Alternatively, you can run a dual boot or virtual computer with an older Windows OS. (Programs like Virtual PC, Parallels and VMWare let you run a virtual computer inside the Vista system with a computer that can handle virtualization.) Unfortunately, you usually need a licensed version of Windows to do this. (Win7 Pro and Ultimate let you do this free with Virtual PC and XP mode.) Then install the software normally in the virtual computer or when booted into the older version of Windows. File transfer can be tricky with the virtual computer - you need to save files to external media (flash drive or optical disc). Printers can't be installed on both the real and virtual computer at the same time.
I hope this helps.
Dec 28, 2010 | Nova Development Art Explosion Greeting...
How want to downgrade win vista to xp pro hp compaq v3000
If you have a Windows XP Pro installation disk, put it in the optical drive, restart your computer, on startup, go to BIOS settings (usually press [Delete] and set the optical drive as first boot device. Save changes and exit. When the computer starts it usually says to press any key to start from CD. Press any key and the windows installation will start. Make sure you format C: and you will downgrade to Windows XP Pro. If you want to upgrade to Vista again, you will need to know the keyboard sequence to start Vista from Its partition or have Vista install disk.
May 25, 2009 | HP Compaq Presario V3000T Notebook
SONY DCR-TRV14E and when i plug the camera into a Visat
There are no drivers for this product. If you talk to Sony directly you might get an answer from them, but as far as I know no Vista drivers have been made for this yet.
Apr 06, 2009 | Microsoft Windows Vista Ultimate Edition
Resource cd for aspire 4315 laptop PC
Some Vista driver may work on XP, however, to avoid any risk of getting in troubles with your Windows xp installation, you can download drivers and utilities for XP starting from this page.
Regards
Jun 08, 2008 | Acer Aspire 4315 Notebook
Visat machines cannot map drive to Snap 4100
According to Adaptec's site, some SNAP servers are not supported by Vista. I've had the same problem with my Vista setup, but I created a new admin local user on the Snap Server administration pages, and used that username and password when connecting to the snap server. So now I've manually mapped connections to the shares using not my domain credentials, but the local user from the snap server.
Apart from the inconvenience it all works fine an' dandy!
Jan 22, 2008 | Quantum Snap 4100 (m4100) Server
I have the window vista soound problem
The notebook i assume has the realtek sound chip, but at the moment their site is down so click on the link below and download the Vista sound drivers and see if they work for you, but it could be that your motherboard manufacturer does not yet have any supported sound driver for Visat. http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/
May 01, 2007 | Gateway MX6450 Notebook
Computers & Internet Logo
47 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
