Question about HP Computers & Internet
My sofware always notified an error on dmy driver
Hi, please help me. when i try to read videos clips in my virtual DJ v. 5.0, my CPU always notified an "error on driver". please help i am a french speaker if possible
Wwwintex3dmultimediasoundcarddriver
Posted on Jun 10, 2008
Video card to slow for windows 7
Hello here is the homepage:
http://www.msi.com/product/mb/K9MM-V.html#/?div=Driver&os=All
Maybe you need more ram, your system supports:
Supports Dual DDR2 533/667/800
2 DDR2 DIMMs (240pin / 1.8V)
Supports a maximum memory size up to 2GB.
Try also to upgrade the graphic driver.
virtual dj takes a lot of power, from the pc:
http://www.virtualdj.com/products/virtualdj/index.html
Depending the size of the cpu.
I think you have to buy a pc, a little faster than you have now.
Good luck
Dec 30, 2012 | MSI K9MM-V Motherboard
VIRTUAL DJ ERROR 8
A solution is to block the application itself from going online using the tool available to download from the link below. This worked for me and only blocks Virtual DJ from connecting to the internet.
http://www.r1ch.net/stuff/nonet/
Mar 21, 2012 | Atomix Productions Virtual DJ
No sound from internal speaker, but I can hear using headset. The problem heppened with Laptop HP 620.
This is a possible damage on the internal speakers or a connection fault at the headphone jack connector. you might need to open the laptop to check and confirm on the connectors.
Jul 25, 2011 | HP Computers & Internet
How to fix virtual dj protection error 16-24-8
write "127.0.0.1 live.virtualdj.com" to your hosts-file of windows C:\Windows\System32\drivers\etc
Mar 07, 2011 | Atomix Productions Virtual DJ
The software "Nuvj" always crash
Hi With Adobe Flash Player 10,0,45,2 installed everything will work ok. Cheers
Nov 25, 2010 | Numark Nuvj DJ Video Mixer
Good day, i have problem with my virtual dj.. everytime i play mp3 after a while it promts me with protection error 24.. pls help..
for this please uninstall the antivirusa u have on the system and then unsintall the virtual DJ then reinstall virtual DJ and at last install anti virus
Feb 20, 2010 | Computers & Internet
My computer with Windows XP Pro SP2 is crashing often, after i had connected a hdd with my computer ============ CPU-Z TXT Report Processors...
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/hdd..
..plz do check the following as in order:..
the Hardware part:..
1)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) 4) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Nov 13, 2009 | Asrock K8NF4G-SATA2 Motherboard
Virtual dj error
select the desktop properties>Setting>Screen Resolution then SELECT MAXIMUM Resolution
means DRAG IT TO RIGHT SIDE
May 17, 2009 | 3M Pro One Dispute Resolution
Driver provlem
Is it possible it's a Sound Blaster Audigy?
http://www-307.ibm.com/pc/support/site.wss/MIGR-51794.html
Hope this helps!
Mar 28, 2009 | IBM Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
