Question about D-Link Computers & Internet
Network cable unpluged error sign
No connection to internet replaced modem and ethernet cable phone cable.
isp response is thatit is a software hw problem
  • little bill Jun 15, 2008
    thanks for taking time to fix my problem. I disabled my network connection then enabled it connection is now fine . Regards Barry
    Scholar:
  • 68 Answers
Hi .
With most issues like this it has something to do with the ethernet cable or modem. If you tried replacing it and stillhave the same issue then it could be on your PC.
You can check device manager first by going through the steps below:
Assuming you are using winxp { almost same steps for vista}:
Start > control panel { classic view} > systems > hardware > device manager and on that window pane look for the +network adapters > make sure your devices ion there doesnt have red X on it . If so right click it and choose Enable. If it has a yellow or red exclamation marks { IRQ conflicts} then you need to reinstall the device by right clicking it and unistall > restart PC and make sure you have your system disk for your PC.
You can also check your network connections by going to start > run > type : ncpa.cpl on the run command and it will route you to networlk connections .Check if your network connection is disabled. , ifYES right click and choose Enable.
If that doesnt hel assuming you have replaced ethernet cable/ modem then might as well buy a new NIC {network interface card} for your PC to isolate the issue.
Other works around for this is using a USB connection to your modem or getting a wireless USB for you computer and get a router instead for wireless conenctivity.
In this way you mayu connect multiple computers in the future and wont have messy cables running throughout your house.
Cheers.Hope this helps.
Let us know soon.
Good luck
Posted on Jun 12, 2008
How do i connect to internet
You have a wired ethernet card (not wireless). You need to plug the ethernet cable into the card. An ethernet cable, also known as an RJ45 cable because its ends are RJ45, looks like a fat phone plug. Phone cords have 6 copper conductors while an RJ45 has 8. You plug one end into your ISP's hardware, which is probably a cable modem or a DSL modem. Plug the other end into the back of your computer. When you plug in the second end, both computer and modem should get a green light to show the cable is connected. If you don't get green lights, try another cable. These cables sell online for $2 to $10 based on length and run from 1 foot to 300 feet. Make sure your control_panel => network => adapter settings are set to "obtain IP address".
I hope that gets you further. Its a very vague and early stage you are at.
Sep 05, 2016 | Computers & Internet
Wireless modems
Connect your computer via ethernet cable directly to your modem then power off the modem for 30 seconds that way should be able to go online if the modem and internet is working fine from your ISP.
Hope that helps...........
Jul 28, 2008 | NetGear WGR614 Wireless Router
Have connected wii to cable via cisco asa 5505 box. getting error code 52020. have restarted comcast modem to no effect.
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
you can also visit this site for more information about your comsole tnxx please rate me if this help you...
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=en_US
Aug 09, 2011 | Nintendo Wii Console
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
May 05, 2011 | Nintendo Wii Console
I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
Sep 13, 2010 | Nintendo Wii Console
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
Connecting modem to WAN port then any lan port to computer provides no connection. straight from modem to comp is ok.
Make sure comp lan and wan are both activated, Make sure the ethernet cable from modem is plugged into the input slot and NOT 1,2,3,or 4
Then after all is connected, unplug main modem for 10 seconds, plug back in, then do the same with wireless router. 5 minutes later, you should be good to go.
You can access the software of you router by opening up an internet page, and type 192.168.1.1 and hit enter. It should bring you right straight to the router's firmware/software where you can change any settings if desired.
If it asks for username and password, the default is usually admin for both. (see owners manual to be exact)
Nov 16, 2009 | D-Link AirPlus DI-524 Wireless Router
Error code 31 4 to 6 network adapter
Check these things:
  1. Is you Ethernet adapter Active
  2. Is your Cable the correct one (NOT a cross over)
  3. Refresh your IP Address for your Ethernet Card
  4. Reboot your computer and power down your modem, then power the modem up AFTER your windows is logged on
  5. Verify your modem "really" can connect, use another computer.
  6. Verify the are no network issues with your ISP
Apr 16, 2009 | Acer AM1610-UD2180A DT E2180 2.0G 2GB...
Setup
Hooking up a router is often more that just hooking up cables. Some internet service providers ISP's (phone/cable/internet companies) have requirements to be configured into the router to allow for communication with their networks. Unless you are sure you understand the ISP's requirements perhaps you could provide a link to the ISP's support website or his name. Confirming the manufacturer and model of the router would be good too just in case the one in the heading of this message in incorrect. If you provide the required information in a comment to this message I will attempt to provide steps to hook up your router.
Generally starting with either a cable or a phone wire out of a phone jack a connection is made to a modem (often supplied by the ISP) the modem is generally connected with an ethernet cable to the wan side of a router and the router is connected from one of 4 lan ports with an ethernet cable to a computer's network adapter. There are variations on this cabling that substitute USB cables or Wireless communications.
Dec 20, 2007 | Ramp Networks WebRamp 700s Router
Computers & Internet Logo
196 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
