Question about Sony Ericsson Walkman® W880i Cellular Phone
Earpiece problem My left earpiece sometimes does not have any sound. Did I press anything that made The sound disappear or appear? please help me I'm desperate.
  • Niels Boehme May 11, 2010
    What makes the sound come back sometimes? Jiggle the wire at the plug and see if it comes in or out.
    Try different earphonesto verify they are ok first.
Pl shake the earphone which is not hearing well
Posted on Jun 10, 2008
I never placed anything in the earjack but when I press the volume key on the left side of my Verizon LG VX 8360, it displays "Earpiece Vol-Earjack" instead of Master Volume. I cannot hear callers and they...
On most phones, the copper contacts down inside the jack work kind of like switches to detect if you have anything plugged in. Other stuff getting in there can depress the contacts, making the phone think something is plugged in.
Get a bright light (flashlight or the like) and shine it down in there. Check for anything unexpected in there, like pocket lint. If there's anything in there, fish it out with some small piece of wire (a paperclip, needle, or the like).
Sep 16, 2010 | LG Cell Phones
Buttons malfunctioning
The problem are in your ribbon wire or some us named Flexyble cable.the keypad that you told are connected with main engine with use a flexyble cable.so if flexyble cable were damaged the problem usually up keypad not working,sometimes no display(blank) or we hear nothing from earpiece.may it help.
May 24, 2010 | Samsung SGH-L760v Cellular Phone
When i make a call i can not hear the caller,but the cller can hear me motorala w510
is this the first time this has happened?
have you dropped your phone?
try a reset of your phone by taking out the battery and the SIM card2_bing.gif. Wait
15 seconds and put it back together and power it on.
I have had this problem and have helped fix others phones this way.
sometimes your phone just needs a hard reset. especially if you leave your phone on all the time.
now,if you have dropped your phone a lot or it had a real bad fall you mayhave damaged something. In this case it is time for a new phone.
Hope the rest helps!
Mar 26, 2010 | Motorola Mobility W510 Mobile Phone
RICOH 2045E COPIER WHAT DOES ERROR CODE SD546 MEAN?
Hello!
Follow the next steps carefully and the error code SC546 will disappear.
Press the following keys by this order:
1. press the (yellow key) [Clear]
2. press then the numbers on the numbers key by order (1)-(0)-(7)
3. press the red key (cancel) [C] and hold it pressed for about 5 seconds.
4. on the screen will appear another menu different from the one
you are
familiarized it will write up in the left corner [service menu],
(if the service menu do not appear repeat the procedure again).
After this menu will appear turn off the machine from the red switch which is located somewhere in the middle of the machine and just by the left corner (the turn off switch-plug) wait for 10 seconds and turn back on the machine by the same switch-plug.
After this the error code SC546 should be disappear.
Please Answer does this was helpful for i to know does the problem has disappear or i should post some other information.
Regards
Jan 12, 2010 | Ricoh Aficio 450 Copier
Grand WEGA continuously displays SATELLITE in upper left
Please press " i " button on TV remote so on-screen display will disappear.
Mar 10, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My htc touch earpiece stopped working i can use speaker phone and blue tooth but earpiece doesn't work.
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if doesnt work then
speaker is faulty just get it replaced it happens sometimes do give me a feed back about it
Feb 21, 2009 | HTC Touch P3450 Smartphone
After startup, all icons and taskbar disappear...
start your machine in safe mode and if you have any antivirus installed in it and is updated then scan it , your laptop is infected with virus . so scan it
Apr 25, 2008 | HP Pavilion dv6000z Notebook
Sounds like Spyware or Adware causing your issues. Try scanning it using http://superantispyware.com/ or AGV Free.
Joe
Dec 17, 2007 | Joy Satellite M55 S3314 Laptop PC
Dialogue vs. background music and sound
The on-screen menu appears only when the selected source is DVD or VCD on the DVD/VCD/CD player and the disc is in the slot and NOT PLAYING. On the remote control ONLY: 1. Press CHOICE (it should work now) LANGUAGE menu appears. 2 Press Cursor to move to the menu you want? which is AUDIO Selected item changes its color to green. THEN: 1. Display EXPERT SPEAKER SETTING menu. 2. Press Cursor to select ?TEST TONE,? then press ENTER. ?TEST TONE? changes its color to green and test tone comes out of in the following sequence?left front speaker, center speaker, right front speaker, right rear speaker, and left rear speaker. ? Test tone is output only when the tray loaded with a DVD is selected, but not playing. 3. Press Cursor to move to ?C.SPK? LEVEL? or ?R.SPK?LEVEL,? then press ENTER. 4. Press Cursor to adjust the output level, then press ENTER. ? You can adjust the output level from ??6 dB? to ?+6 dB.? 5. Repeat steps 3 and 4 to adjust the other speaker output level. 6. Press Cursor to select ?TEST TONE,? then press ENTER. Test tone stops. 7. When finished, press Cursor to move to ?EXIT,? then press ENTER. EXPERT SPEAKER SETTING menu disappears. I hope this helps you, please let us know. Best regards, nightdiver
Jun 13, 2006 | JVC MX-DVA9 Shelf System
Sony Ericsson Walkman® W880i Cellular Phone Logo
46 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
