Annovi Reverberi RMW2.5G25D Logo
Posted on Oct 28, 2010
My RMW 2.2G24 will not pump water - Annovi Reverberi RMW2.5G25D
Hull
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 24, 2014
Hull
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
17952
Points
19
The cheapest pump I have found (for your model) is RMW2G24 2 2 GPM 2400 PSI Max pump on amazon. Hope this was helpful... cheers
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Jun 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
19390
Points
39
I had the same problem with my pressure washer that I bought from Home Depot. Only two years old and used about four times. Home Depot said 'sorry, no warranty' but offered to put a $160 pump on it if I paid for it; however, I only paid a little over $200 brand new (was on sale) for the whole washer!.
In anycase, I watched a couple of video's on U-Tube and disassembled the pump. Well, all the little plastic valves in the pump are damaged and now mis-shapened.. I guess that is that..
It does not seem to be possible to buy a rebuilt pump. Further, the parts cost almost as much as just replacing the pump which is why you can't get a rebuilt one. So, I am buying a new equivalent pump from a different OEM on Amazon and suggest you do like wise.
You might save a few $ by buying the rebuild kit, but if it doesn't work you are still out of luck. At least the new pump should work a few hours...
Anonymous
Level 1:
New Friend:
  • Posted on Oct 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
17952
Points
Yes..I'm having the same problem.This pump was made in China for Annovi-Reverberi and they are junk.I'll see if I can get a Cat or any other brand that fits.
alan martinson
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 76 Answers
  • Posted on Nov 25, 2014
 alan martinson
Contributor
Level 1:
New Friend:
Cheetah:
Answers
76
Questions
0
Helped
58773
Points
82
See link for upgrade pump head.
http://www.ppe-pressure-washer-parts.com/product/1001.6677
Ball valve spring pressure washer detergent line
Not sure what type pump you have but you can buy a chem. injector rebuild kit at Pressure washer parts catalog quick links Pressure Washers High Pressure...
If you need to replace the spring then replace the entire kit. Ball, spring and oring. Most pumps that come on the newer TRoy bilts are AR RMW pumps. the parts diagram can be found here at http://www.arnorthamerica.com/manuals/rmw-om%201006.pdf
The parts for a AR chem. injector are
480480 O-Ring
1250280 Ball
1560520 Spring
Good luck
1helpful
How to fix power washer with no pressure with out have to buy the hole pump what can i do to fix it
Cover soap inlet and retry. Mine will not pressurize without soap or without inlet covered.
High pressure wont shuy off
do you mean it keeps trying to build pressure even when you release the trigger on your wand???that is a problem with your unloader....also checkout your shutter valve and replace the oring on it. You will need the diagram here to know what parts Im talking about Pump Breakdowns and you can order parts here Pressure washer parts catalog quick links Pressure Washers High Pressure...
Where is detergent port
look at the schematic here Pump Breakdowns more specifically here http://www.arnorthamerica.com/manuals/rmw-om%201006.pdf Now look on page 13...part number 17 is the hose nipple ...now locate that on your pump ..that is were your chemical hose attaches and your draw chemical into.. good luck
1helpful
Oil capacity on rmw 2.2g24
4.5 ounces
Changing the oil in the pumps is not required but if you need to then Ar makes its own oil for the RMW pumps. #64545
My Husky Pressure Washer bogs the motor down immediately upon start.
Rebuilding the pump is not easy. Did you use the right seal drivers? Lube the seals when you installed them? Use a torque wrench? But a valve in backwards?
May 04, 2013 • Garden
10helpful
My Husky pressure washer 2600 psi powered by a gcv 160 Honda. Engine starts no pressure other then from water source and soap is not being dispensed
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Jul 10, 2010 • Garden
Top Annovi Reverberi Garden Experts
Jay Finke
Jay Finke
john h
Are you an Annovi Reverberi Garden Expert? Answer questions, earn points and help others
