Question about Ricoh Aficio 1035 Copier
Fax Facility When I connect the Machine to the phone line, it answers the calls immediately rather than ringing more than 3 times. It is the same line as my business number so I cannot use at the moment.
  • 1 more comment
  • PAZ 21 Jun 10, 2008
    The model number is Aficio 1035
  • Tim Babcock
    Tim Babcock May 11, 2010
    Were looking it up right now. It isn't a key operator function. Were checking the service guide to see if it is a bit switch setting.
    Stand by
  • Tim Babcock
    What model number is that copier?
  • Ricoh Master
  • 2,794 Answers
You need to get a hold of a service tech to do it. It is an NCU parameter. If it isn't set properly, unpredictable results can happen to the machine.
This procedure involves modifications to the RAM addresses. It isn't a bit switch adjustment.
It's a very archaic way Ricoh did this.
Posted on Jun 10, 2008
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
How do i connect my hp 1240 fax\printer to my computer
The fax must be connected directly to the wall phone jack. Connect any other phone line devices, such as a telephone or answering machine, to the phone jack on the back of the fax
The phone line cable used to connect the fax must be a two-conductor (wire) phone cable, like the one that shipped with the fax. The fax may fail to send or receive faxes if the phone cable has more than two conductors. To determine how many conductors the phone cable has, look at the end of the cable. Most phone cable connectors are clear and you can see the number of wires
The Rings to Answer setting determines how many times the line will ring before the fax answers. Follow the steps below to change the rings to answer setting.
  1. Press Setup , press 3 , and then press 3 again to access the Rings to Answer setting.
  2. Press the Right Arrow to scroll through the available settings. When the desired number of rings is shown in the display, press OK .
To receive faxes manually, follow the steps below.
  1. Answer the phone like you normally would a telephone call. If the incoming call is from a fax machine, you will hear beeps or fax tones.
  2. Press either Start Black or Start Color to begin receiving the fax.
  3. Hang up the phone.
Jan 15, 2011 | HP 1240 Plain Paper Inkjet Fax
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Every time when the phone rings and I answer it the fax kicks in with that really annoying sound. I have to shut down the fax and plug it back in after I am done my call. what is the normal setting for...
The fax is on what you call a Distinctive Ring tone. You need to go in to the settings on the fax machine, and look for Ring type, or Distinctive Ring, And set it to 2 or 3, Dependent on how the phone rings on the fax number.
Nov 25, 2008 | Samsung Office Equipment & Supplies
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Fax answer machine
FAX RECEPTION THROUGH AN ANSWERING MACHINE:
This mode is recommended for a shared fax and telephone line.
To receive a fax if your All-In-One is connected to an answering machine:
On the control panel, press Fax.
Set the answering machine to answer incoming calls before the All-In-One does. For example, if you have set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
To change this setting on the All-In-One:
Press Options until Number of rings appears.
Press the right arrow (+) until After 5 rings appears.
Press Select.
Make sure the Auto Answer light on the All-In-One is on. When a ring is detected, the answering machine picks up the call.
If a fax is detected, the All-In-One receives the fax, and disconnects the answering machine.
If a fax is not detected, the answering machine completes the call.
Feb 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Ricoh Aficio 1035 Copier Logo
43 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
