Question about HP Cameras
I had purchased a photosmart r847 camera.the battery is fully charged,but i am unable to get an image.It is necessary for me to install a memory card?
  • gbernai 1914 Jun 16, 2008
    only had to take battery out for about 30 seconds.then replace it.camera now works fine,thanks for trying to help jackboy
    Genius:
  • 2,985 Answers
Yesw of course where else would go?
Posted on Jun 10, 2008
Lost cd for installation r847
Improve the Fixya.com experience for everyone by voting!
HP makes it easy for you to download virtually everything on the installation CD.
  • Click on the following link for the download site. Driver Download
  • Follow the instruction and you should have everything that you need.
All the best,
Ben
Jul 07, 2011 | HP Photosmart R847 Digital Camera
Hp photosmart r847...."card locked" how do i
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 02, 2011 | HP Photosmart R847 Digital Camera
I haven't any problem till now. The photosmart R847 will not download the pictures to the computer...what can I do?
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 22, 2010 | HP Photosmart R847 Digital Camera
Charging battery not working is saying depleted and then shutting down.
this error shows that the battery is not charging, or is damaged and need to be replaced.hope this helps pls do let me know
Apr 06, 2010 | HP Photosmart R847 Digital Camera
Won't turn turn on. A red and green light comes on, but nothing on the screen.
Step one: Reset the camera
  1. If you have an optional memory card installed, remove it.
    NOTE: Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.
  2. Remove all batteries from the camera for at least five seconds.
  3. Reinsert the batteries and close the Battery/Memory card door.
  4. After verifying that the camera works without an optional memory card, reinsert the card if you removed one in Step 2.
Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
  • If the is not resolved , continue with the next step.
Step two: Check for damage or corrosion on the batteries
  1. Open the Battery/Memory card door on the camera.
  2. Remove the batteries.
  3. If the batteries are damaged or show corrosion, replace the batteries.
Step three: Recharge the batteries
  1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
  2. Try turning the camera on after the batteries are fully charged or have been replaced.
Step five: Ensure the batteries are installed correctly
  1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
  2. Try turning the camera on.
Step six: Turn on the camera without the memory card
  2. Remove the batteries and optional memory card from the camera.
  3. Wait 15 seconds.
  4. Re-insert the batteries into the camera, but not the memory card.
  5. Try turning the camera on.
    • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
    WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
Step seven: Service the camera If the camera still will not turn on, service the camera.
Mar 04, 2010 | HP Photosmart E327 Digital Camera
FOLDER CONTAINS NO IMAGES.
Please follow the instruction below and let me know what is happening.
1. format the new card.( Can't format is from any virus
infected PC ).
2. Insert the card then reset your camera setting.
3. select your mamory card default for save the
photographs.
4. Before start photography confirm that your battery
is fully charged.
Thnaks & please give me feedback about your camera.
Feb 03, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Battery is fully charged but when I push button to take a
Camera takes pictures with flash off. With flash on message comes up and says flash charging and camera freezes unable to turn off I have to take the battery out
Jul 12, 2009 | HP Photosmart R707 Digital Camera
Error Saving Image
From HP's website:
Check this document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00191836&lc=en&cc=us&dlc=&product=410648
Error saving image or Error saving video. The optional memory card that is installed was removed before the camera finished writing to the card or was half-locked.
  • Always wait until the Memory light stops blinking before removing the memory card from the camera.
  • With the camera turned off, remove the memory card and check to see if the locking tab on the edge of the card is fully in the unlocked position.
Also, check this link:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?cc=br&lc=en&docname=c00017052
You might just have to reformat your memory card.
Mike
Nov 12, 2007 | HP Photosmart M517 Digital Camera
Cameras Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
