Question about HP Pavilion dv2000t Notebook
My battery died on my hp pavilion dv2000
My battery died on my pc I recharged it and had it connected to a power supply but now when I start it up it appears that the hard drive is not working, I cannot hear it running and the screen will not come up
  • ksmith7 Oct 21, 2008
    The Battery Discharged and Laptop turned off before i could get it plugged in to power strip. Now the fan comes on and sounds like it goes thru normal start up, but the sreen will not light up with promps. I did hook it up to another monitor and still does the same. can you help?
    Genius:
  • 1,605 Answers
Take the battery out. unplug the AC.
push and hold the power button for 20-30sec. plug in the AC and turn it on. if the laptop comes on, let it finished the loading. shut it down and insert the battery.
you may have to this twice.
Posted on Nov 03, 2008
How to fix hp dv2000 power problem
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 12, 2013 | HP Pavilion dv2000t Notebook
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
HP dv2000 fails when power supply connected
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
Jan 04, 2010 | HP Pavilion dv2000 Series Laptop Full...
My HP Pavilion 753n starts to be and then
It is the power supply
In hp the power supply they use does not die on you completely; it will start but not feed the computer.
So change it to generic brand and every thing will work fine.
Jan 02, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
Hp pavilion dv2000 Turnoff due to overheating
1) plz go to power options from control pannel and change the power options as never never
2) we can do one more thing,we can do a Bios update
everything tis going to fine
ITS Works
Dec 06, 2009 | HP Pavilion dv2000t Notebook
My hp pavilion dv2000 will not boot up. the
Could be the dc connector has come loose from the motherboard or broken away inside. Take the machine to a repair shop and have them check it.
Jun 09, 2009 | HP Pavilion dv2000t Notebook
HP Pavilion dv2020us laptop battery won't charge
How is your power supply? does it seem like you have to wiggle your cord that connects to computer to make it recieve power?...Many laptops power supply become loose over time form moving the cord around..when it does, the battery has a hard time getting electric power to recharge. Also, you my have other problems with your lithium internal battery that powers your cmos.
Check to see if your power supply is loose and go from there. the power supply is the little hole where you connect the cord to the laptop.
let me know what the status is
Apr 10, 2009 | HP Pavilion dv6000z Notebook
Hp pavilion dv2000 no lcd dispaly
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Sep 24, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
No power
did u change the bat??
check the recharger of the notebook
by just simply plugging it wd out bat and start the comp if it wrk the bat is gone if not
then chek the adaptor or the power supply of notebook
May 20, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv2000t Notebook Logo
253 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
