Question about Sherwood A-965 Amplifier
Sherwood AX4103 Amplifier Problem
I recently came about a Sherwood amplifier. Problem is, it powers up fine, display works and all, but there is no sound comign through. Volume knob works fine, and as far as i can see the wiring is solid. I've connected it to two crappy speakers, but nothing using the auxillary input. Any help or info greatfully recieved.
  • Anonymous Sep 26, 2008
    xvcxcvcxvcx
Sherwood CDC-5506 5-Disc CD Player - does it need Amp ?
Yes you need and amp Look at the disc player there is no volume control or speaker outputs.
Nov 21, 2013 | Audio Players & Recorders
Sherwood receiver - no sound for DVD or cable
ok..i'd recommend you test this on one of the audio only settings, like radio or cd, and see if it's the main amplifier or somewhere else
Apr 27, 2008 | Audio Players & Recorders
I recently installed a sony explode in my truck everything works fine except for when u put a cd in, no sound and the display shows the cd is playing and all the function buttons work i just have no soud...
It sounds like you are using an amplifier. Make sure you are using the blue/white wire to turn the amplifier on. The blue/white wire is amplifier remote turn on and the blue wire is power antenna remote turn on. The blue wire turns off when leaving tuner mode, turning the amplifier off.
Aug 24, 2011 | Sony Xplod CD Player w/MP3 Playback...
When powering up the Sherwood RVD-7090R Amp, it switches off again almost instantaniously.... Any suggestions ??
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check that it gose to standby again ( protect show) or not . if not, then any of the speaker is damaged. If then also it shows protect you have to check the amplifiers hardware.
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally AV receivers show this when any of the output amplifier have some problem. there are five amplifiers in this AV receiver. This problem occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
For that you need digital multimeter,soledring iron screwdrivers etc
Open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Aug 11, 2011 | Sherwood RVD-7090R
I recently installed my sony xplod to my jeep and the radio, volume works fine. when i insert a cd, i hear nothing, counter and track displays but no sound...please help
are you using an amplifier? if so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on.
Feb 17, 2011 | Sony XPlod CD Player w/MP3 Playback...
I have a Sherwood AI-2110R Amplifier system - but no manual and I'm wanting to know what the 2 sets of plugs marked "EXT" can be used for please? We are trying to hook up a surround sound system which...
I was looking for informations about the Sherwood AI-2110R and it seems to be an integrated stereo amplifier with good power. However the "external" plugs seem to deliver only the "passing" sound, what means that the signal needs to be powerd by an external amplifier. I donĀ“t believe that a simple surround set would be able to do that. Maybe the best solution would be to hook another amplifier to the external plugs, via an "aux" connection.
Sep 18, 2010 | Audio Players & Recorders
Amplifier Powers on But Does Nothing!
Try finding a better ground some amps are more finicky about ground than others. Try running a wire from the ground on your battery to the ground on the amp if this works then you will know you need to find a better place to pick up a ground.
Jan 24, 2009 | Pyle BZDBP212 Car Subwoofer
Connecting remote cable to other port from the car stereo
You can tap the amplifier's remote wire into the accessory power lead at the back of the head unit. On most head units this is a red wire. Doing this will make your amplifier turn on and off with the key switch, rather than the deck power.
Jul 01, 2007 | Sherwood XCM-6870R CD Changer
Sherwood amplifier rv-5106r
if your skilled enough,concentrate only on the power supply circuit and try to check some chips,if not see a qualified tech.
Dec 03, 2006 | Sherwood A-965 Amplifier
263 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
