Question about Thermador 48 in Built In Side by Side Refrigerator w/ Masterpiece Handle - KBUIT4855E / KBUDT4855E
Thermador 48 in built in side by side refri.
How do you install the front door panels ...new appl. but no instructions
  • 13,433 Answers
See if you can find your refrigerator from this listing
click here
Posted on Jun 10, 2008
  • Ekse Jun 10, 2008
    just enter your model number there or look around, you should find a use and care manual and also installation instructions.
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Ice maker overfill
it sound like you have a leaky water valve or the ice maker is calling for to much water, can be adjusted.
Apr 19, 2014 | Thermador 48 Built-in...
Thermador condenser coils
Could you please describe the problem you are having a little better?
Oct 27, 2012 | Thermador 48 in Built In Side by Side...
Refrigoator door does not vacuum seal tight like it used to when new. Door barely stays closed on gasket.
What I hears sounds as if the refrigerator needs re-leveling. Here are some basic things to do as in this video. Every refrigerator is not always the same but the idea is to cause the doors to shut inward if you should be standing in the front and let both doors loose from your hands the doors should shut inward and firmly if not over adjusted in the final steps. Your model is a nice large model! Here is what one user manual mentioned below.
NOTE: Custom or full-overlay door panels must be installed
before leveling.
1. Open the door and place the level on top of the refrigerator
frame as shown. Check to see whether the refrigerator is level
from left to right.
2. Use the leveling bolts to adjust the leveling legs until the
refrigerator is level from left to right.
3. Place the level(s) on shelf or shelves. Check to see whether
the refrigerator is level from front to back.
4. Use the leveling bolts to adjust the leveling legs until the
5. Be sure that all four leveling legs contact the floor and
support the full weight of the refrigerator.
6. Make final check to ensure the refrigerator is level.
Adjust Door Swing
1. Check that the refrigerator door can open freely. If the door
opens too wide or you are installing full-overlay custom
panels using a Trimless Trim Kit, you should adjust the door
swing.
2. Remove the door stop screw from the bottom hinge.
3. Hold the door open to a position that is less than 90°.
4. Replace the door stop screw in the bottom hinge and tighten.
NOTE: If you are using full-overlay custom panels with the
Trimless Trim Kit, the door stop should be replaced in either
the 90° or 110° position. See "Handle and Door Clearances
for Custom Panel Series."
Install Side Panel
If the built-in area depth is 25" (63.5 cm) or more, the side panels
can be installed inside the side trim or attached to the outside of
the side trim.
IMPORTANT: Thermador is not responsible for the removal or
addition of molding or decorative panels that would not allow
access to the refrigerator for service.
1. For the inside side trim piece, slide the front edge of the
routed side panel into the trim piece.
2. Nail the rear edge of the panel to the support board.
A. Level to check left to right leveling
B. Level to check front to back leveling
A. Rear leveling bolt
B. Front leveling bolt
A. Door Stop in 130° position
B. 110° position
C. 90° position
AB
AB
Thanks, Sea Breeze
How To Level Refrigerator Doors
Apr 21, 2011 | Thermador KBUIT4870A
Handle you close the door (drives door)one end came undone
Maybe these instructions will help you take the door apart: REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Mark the location of the door hinges on the door.
  3. Remove the door trim panel and water deflector.
  4. Label and detach the electrical connections.
  5. Remove the rubber conduit and the wiring harness from the door.
  6. Support the door with a suitable jack, being careful not to damage the paint or trim.
  7. Remove the bolts from the door side of the hinges and remove the door with the aid of an assistant. To install:
  8. Position the door to the hinges with the aid of an assistant. Install the bolts.
  9. Adjust the door for proper door-to-body alignment and lock-to-striker engagement, then tighten the bolts to 38 ft. lbs. (48 Nm).
  10. Attach the wiring harness and rubber conduit to the door.
  11. Attach the electrical connectors.
  12. Install the water deflector and door trim panel.
  13. Connect the negative battery cable. Fig. 1: Front door hinge1990—93 Deville and Fleetwood; others similar 84200001.gif
    Fig. 2: Rear door hinge1990—93 Deville and Fleetwood; others similar 84200002.gif
Jul 03, 2010 | 1993 Cadillac DeVille
Detergent dispenser replacement
The front door panel can be removed from the stainless steel inner panel to get to the rear side of the dispenser.open the door & there will be screws along the side.the panel should come away exposing the rear of the dispenser wich then can be undone & replaced.
Jun 04, 2010 | Frigidaire 24 in. GLD3450RD Built-in...
Where is the model number located
normally it is on the inner panel frame of the machine which is around the door right or left side. when open the door check that location you will see it. or you can go to thermador .com they own bosch and they can get all of the parts that you need.
Mar 03, 2010 | Siemens 24 in. SL84A305UC Built-in...
Want to replace painted front panel with stainless steel
The installation instructions and the Owner's Manual do not say how to replace the panel.  It may not be possible to change without replacing the entire door.
Look for trim near the top of the door that is attached by screws.  If the trim can be removed the old panel can be slid up and out and the new panel can be slid in.  Alternatively look for side trim piece(s) that might be removable allowing the panel to be slid in.
Jun 02, 2009 | Maytag MDB9600A Jetclean II Built-in...
Thermador 48 in Built In Side by Side Refrigerator w/ Masterpiece Handle - KBUIT4855E / KBUDT4855E Logo
287 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
