Question about Tomtom GO 300 GPS Receiver
Battery will not hold charge on tomtom 300
    Novelist:
  • 158 Answers
TomTom will not service tomtoms out of the warranty period. I tried them and they dont . They say / argue that there are many companies offering service . I would suggest that the battery is user replaceable with a little bit of DIY knowledge. You need the correct screwdrivers whicth are Torx type. You can buy them cheaply in sets from size T5 up to T20. First remove screen surround by pushing the windscreen mount clip underneath the tomtom , towards the screen. This will push the surrounf out enough for you to grab the bottom of it and pull it off. Next unscrew the 4 torx screws located in 4 holes around the screen. Next , extract the tomtom 'innards' by easing the assembley out of the front of the case. Next , unscrew the 2 torx screws that hold the speaker in place. Next , remove the 2 smaller torx screws UNDER the speaker. This will then allow removal of the plastic clamp that holds the cylinder shaped battery in place.NEXT , unplug the battery ( theres 3 wires go to a little plug on the circuit board ) and withdraw it through the gap left by the speaker. Fit NEW BATTERY ( available off ebay ) and reassemble in reverse order. Of course all this should be done very carefully. DO NOT RUSH. Work on a clear bench and put something soft on the bench to protect the tomtom. DO NOT force anything , it should all come apart easily. If you are unsure , inexperienced at messing with fiddly things or just plain nervous then get someone else to do it.
Posted on Jun 12, 2008
Throw the thing away and buy a good one
Posted on Aug 16, 2008
    Sergeant:
  • 250 Answers
Hello magoo555,
Sorry to hear about the problem with your GPS. Your TomTom GO 300 GPS has an internal battery which will wear out over time. As the battery ages the amount of time you will be able to operate your device between charges will decline. Eventually the battery will fail and will need to be replaced.
Unfortunately, like most other GPS units, the battery in the TomTom 300 is not replaceable by the end user. For service on the battery, contact Tom Tom directly. You can find contact information on their website at:
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jun 10, 2008
2 Suggested Answers
vanherringto
  • 1738 Answers
SOURCE: the battery on my tomtom 720 no longer holds the charge
You can purchase a new battery on eBay for less than $20 including shipping:
Click here: http://bit.ly/bgoqZ0
Posted on Feb 07, 2010
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
WHY isn't MY TOMTOM CHARGING? It's BEEN PLUGged IN FOR 45 MINS.
Usually an old (or older) battery will no longer hold a charge ... or will only hold a small charge (that will let you run the GPS for only a few minutes).
Often, when the TomTom device is always connected to the charger (in a vehicle), where it charges every time the car is turned on, whether the TomTom is being used or not, the battery gets charged (partially or fully) often enough to use up the "maximum number of charge" cycles for the battery. Hence, it will no longer charge properly or hold a strong charge.
Like for all lithium batteries, it's better if your device is not always connected and being charged (whether you are or are not using it). The battery will last longer and it will still be able to hold a stronger charge.
Feb 24, 2016 | Tomtom GPS
Tom tom troubleshooting
Your GPS will "freeze" (i.e. stop and shut down) if / when the battery level is low on the TomTom. If you have plugged it in a power source to charge it and the battery indicator shows that it is fully charged ... and then, when you unplug it from the power source, it freezes after a short period of time, it is likely that the battery will no longer hold a good charge.
If it does that while the TomTom is plugged into a power source, it indicates that the battery does not hold a charge anymore.
If this is the case, you may wish to get the battery changed (at an authorized TomTom service center, or do it yourself ... after getting the appropriate replacement battery and the tools/kit, and instructions). Just remember to follow the (initial) charging instructions (after you get a new battery) ... to ensure that the battery will hold a good charge for a long time.
Or junk it and get a new TomTom.
Aug 12, 2014 | Tomtom VIA 135 Automobile Portable GPS...
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
We bought tomtom GO 300 on 12/19/2005. Have not
go to tomtom.com, go to support, search for reset, select your device do as told. includes fotos of resetbutton and good discription. first make sure battery is full. goodluck.
Dec 03, 2009 | Tomtom GO 300 GPS Receiver
Tomtom910 not holding charge or charge properly
Looks like the battery needs replaced. Go to: http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
This site will give yo step by step how to change the battery. Good luck!!!
Oct 03, 2009 | Tomtom GO 910 GPS Receiver
Tom tom go 300 wont turn on
c48ee42.jpg ctf1800
Rank:guru_s.gif Guru
Rating: 85%, 3949 votes
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
Apr 18, 2009 | Tomtom GO 300 GPS Receiver
under warranty, have tomtom fix it, do not open it.
Sep 21, 2008 | Tomtom GO 300 GPS Receiver
Tomtom one
After a reset, hold down the power on button for at least 15 sec...
May 17, 2008 | Tomtom GO 300 GPS Receiver
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
666 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
