Back to:
Tags:
Ovens
Generic problem for all Ovens
DeLonghi doubleoven electric cooker ESS602
posted by June1634 on Jun 10, 2008
The lower oven has ceased to heat up. The fan works.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 16, 2008
Not Rated (0)
Bob from LI
Rank:Guru Guru
Rating: 85%, 443 votes
It is hard to know exactly from here. I'd suspect the heater element is open before anything else. If you can get to the terminals of the element itself (unit unplugged!, element disconnected on at least one side), then test for resistance with an ohm meter...available at any electronics shop or large retailer like Radio Shack, Sears Hardware or the Depot.
If there is none, the element is bad...hint: defective elements often have an area on them that is discolored differently from other parts. Food particles, particularly grease splash, will cause burnout. Terminals or connectors that are loose or corroded will cause non-function or failure. Look for those issues. Make sure all connections are tight when you're finished.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on DeLonghi doubleoven electric cooker ESS602:
I don't want to Accept this solution
Can you Help with these Ovens problems?
Neff U1721 Double circotherm Electric Oven
No heat from bottom oven, fan and light is working ok....
GE JKP28 Electric Double Oven
I have a Model JKP28/911.4772. The bottom oven stopped...
GE Profile JKP56 Electric Double Oven
Oven was not in operations, but code F1 appeared and oven...
Neff B1421 Electric Single Oven
Have lost instruction how do you set the timer
Stoves 720EF Electric Double Oven
what kind of paint do you use on your oven? is it an...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
