Question about Dell Dimension 2400 PC Desktop
Zapped by lightning
My motherboard is toasted by lightning thru the LAN card. wonder if there any fuse that can be changed and everything would be alright?
tried to fix in an optiplex gx240 but would not fit.
  • Dell Master
  • 1,183 Answers
Have you removed the network card from the computer ? Check the same by removing the same. If you have burnt marks on the system , then there is nothin much we can do , other tan putting in a new motherboard.
Thanks
mandeep
Posted on Jun 10, 2008
M3N78-VM LAN PORT& PCI PROBLEM
1) How do you know that PCI slot is not working? Tried another PCI expansion card in it? Perhaps another LAN adapter card?
(Ethernet Card)
A LAN adapter card will go bad before a PCI slot will.
2) PCI expansion slot is bad? No other PCI slot to use?
Then here is a suggestion,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3504463&csid=_61
Plug it into any available USB port on the computer.
It is a GigaByte Ethernet solution, also. (10/100/1000)
Regards,
joecoolvette
Aug 08, 2012 | ASUS Computers & Internet
When i connect the lan wire my mother board shows lan not connected why/
Either the cable is defective (it has a break inside it so try another one) or the onboard LAN chip was fried by the power surge generated by a lightning strike that came in your vicinity.
That is unfixable, disable the onboard one from the BIOS and install a simple PCI LAN card in its place.
Aug 17, 2011 | Intel D945GCCR Motherboard
Lightning strike nearby, no power from the card what so ever
The most likely explanation is the high voltage from the lightning has probably zapped the sensitive electronics. It is however worth checking all the fuses are OK
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | Sony Televison & Video
Announcement msg zapped by lightning
No, the message must be redone.
Apr 17, 2009 | Lands Phones
"zapped" tv (dee7189)
I would need more details on this problem. Does the tv turn on? If so, what do you see on the screen? If you mean by "zapped" that the tv received a lightning strike and does not turn on, it's possible there are several damaged circuit board components. Depending on the severity of the strike, it's possible that just the fuse is blown. I need more details to advise further.
Rick.
Jan 18, 2009 | Insignia NS- 27" TV27 TV
On board lan & pci slots are not working . on board lan also not showing in device manager.
Was the board recently struck by lightning? I've had several problems where lightning struck the motherboard through the lan ports, while not destroying the board itself, but just the lan port, and usually not showing up in device manager gives it away.
You will have to replace the motherboard if this is the case
Dec 30, 2008 | Intel D101GGC Motherboard
Sony de898 no sound
Could be an internal fuse blown but most later electronics use a special kind of resistor called a varistor. These devices are across the AC line and do nothing until the voltage difference between the two lines, hot & neutral, exceeds a certain voltage; this is typically ~200 volts for 120 service as in the US and higher for 220 service on most of the planet.
They are disc shaped, will be from 4-5mm (~ 3/8") to as much as 25mm (~1") in diameter and if ever zapped, they are charred and with chunks missing.  When their design voltage is exceeded, their resistance drops from near infinite to a few Ohms which then causes the fuse to blow. You can replace the fuse and choose not to replace the varistor but then you will not longer have even that minimal protection against spikes.
For folks in lightning-prone areas, the installation of a 'whole-house' surge suppressor is highly desirable, will cost ~$250 US and have an insurance policy against losses of $10-$25,000 US in case you still lose devices protected.
Dec 19, 2008 | Sony STR-DE898 Receiver
D-Link DFE-530TX+ installing on our desktop
That cable could be the wake-on-LAN cable, it is used for the connection of the card to the motherboard's wake-on-LAN slot, this is only used if your motherboard supports wake-on-LAN and you want to open your pc remotely from another location. But if don't need remote pc connection you don't need to install this cable.
Jun 16, 2008 | Televison & Video
Lan card disabled
When u plug the ethernet CAT cable in the LAN card socket , so you see any light orange or green flashing on the LAN card itself.
If yes then right click on my computer >> properties >> Hardware >> device manager>> check in network adapters whether the LAN card is enabled or not
If NO the right click on it and enable it check whether it is able to receive any ip address
If u see no light at all
Then you might have to install a new LAN card on the system
Jun 07, 2008 | 3Com Megahertz 10/100 with XJACK Connector
Lightning
In a nutshell, yes and not only to a Dell but to most computer brands/models. In some instances, it's only the modem, router, LAN card that gets fried while some gets everything toasted.
Incidentally, even a near lightning strike is enough to cause big problems.
Kind regards.
Dec 12, 2007 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
60 people viewed this question
Alun Cox
