Question about Maytag Washing Machines
Maytag washer sav2555aww
Water doesn't leave tub.
    Brigadier General:
  • 6,966 Answers
It could either be the filter (most likely), the drain pump (likely) or the drain hose/tube (least likely).
Normally, there would a filter somewhere at the bottom of your washing machine with the primary function of keeping loose clothing, torn fabric, lint, fluff and foreign objects away from the impeller/pump. Most current washing machine have self-cleaning filters and therefore regular cleaning is no longer a concern. However, some other washing machine need to have the filter manually removed and cleaned regularly or as even in your case. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your washing machine and may cause the problem as you have described; water doesn't leave the tub.
To check the filter and/or the drain pump, the bottom has to be exposed, the filter/pump located and cleaned. In some instances, the drain could be a valve operated by a solenoid.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 10, 2008
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Tub not draining in washer
If it won't drain, something is plugging the drain system. Start from the hose end. Make sure the hose is open at the end. Try lowering the hose to almost floor level. Make sure you have a pail handy. The water from the tub will be higher than the hose end and the blockage might come squirting out. Put the hose back into the sink or drain pipe it was in.
If water comes out of the hose, but the washer still doesn't "drain," turn it on to a point in the cycle where it should be draining (spin cycle). Listen to hear if the pump is running. If it isn't, there might be something caught in the pump, the pump impellers (that push the water through the pump) might be stuck or broken. This will require a service person.
A third thing you can try if you feel really handy, is to figure out how to open the top of the washer. (Do this with the washer unplugged.) This is often a couple of spring clips near the front edge. Push in on these clips with a putty knife or something else thin, while lifting the top. Once you get it open, scoop out the water between the tubs if you want to. Other wise reach in between the tubs and find the drain hole where the water leaves the outer tub. This happened to me once and there was a child's sock in the hole. Pull out the blockage, reassemble the washer, plug it in and see if the pump check works.
Like I said, it's the outer tub, the pump or the drain hose usually. Good luck.
Jun 14, 2012 | Maytag Washing Machines
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
I have a Maytag Neptune model # MAH5500BWW. It appears that there is still water inside the tub after completing a wash cycle. I only noticed it as I tried to get a stuck sock from the top of the tub and...
the noise you're describing is normal - there is water in a sealed balance ring on the inner tub. To get rid of the mildew and smell, leave door open after cycle and use something like Affresh or "Smelly washer" stuff monthly or more often.
Vlad,
First Choice Appliance
Aug 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag will not spin on spin cycle. water empties out OK but just won't spin? Muzza
it may have a build up ol lint. under tub or in the drain out let this would leave water under tub / as it floats. and if it cannot drain comlpetly ( no spin also ck for a kink in drain . or a bad pump . hope this helps ..
Dec 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Mah 6500 spins but leaves som water in tub. if you
they have a balance ring on the front of the tub and it's full of water
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water built up in Maytag Washer Model MAV-17
I would check the water valves or the water lines. If the water valve is leaking, the water could be running out and following down the cabinet then in to the tub, or the water valve water line that leads right in to the tub there for leaving a water build up.
Mar 01, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag PAV2300AWW Washer leaks while filling
Hello
Welcome to Fixya
My name is Huum,
Why did you change the hoses with old ones?
If you are going to change them use new ones!
Sounds like the drain hose connection to the washer is not tight or not secured, or not fitting th connection because it is from a different washing machine.
Or there is a hole in the inner tub and leaking out on the floor.
Do you know the ones that sold it to you?
Thank You For trusting us with your question
Please remember to leave a rating before you leave!
Dec 14, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
319 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
