Re: Lacking suction from largest filter I don't know how...
Hi there VacuumGuru for nelsonvacuums and VacuumSpot here. I have actually made a video on how to locate and change your filters for the dyson dc07. See link below.
Hi. The hollow noise and lack of suction suggests there is still air flow restriction. Start from the furthest point and work back towards the motor. Pull the hose off at the machine. Has high suction returned to normal? If not, open the canister and expose the filter bag. Remove the filter bag and check for a blockage or is the bag full? If the bag is not full and there is no blockage inside the inlet tube. Leave the hose and the filter bag removed, close up the canister vacuum and turn it on. Has high suction returned to normal? If not, there is probably a secondary filter or HEPA filter that needs to be replaced. I hope this helps. Please let me know what you found. Good Luck.
Hi there, You don't actually specify how long it takes to turn off but this is normally due to a blockage in the hose or due to excessively dirty filters. Given that you have said the suction is low i would be inclined to think you have a blockage in your hose. Remove the hose and test suction of the machine again. If you have a notable improvement it is telling you something is stuck in the hose which you will need to remove.
I have made a video of the two most likely causes for lack of suction in the handle of your dyson DC07. Watch the video and see if it helps. The other thing to check is your washable filter, this can cause a big resuction in suction if dirty. If this is helpful take a moment to leave a testimonial or a thumbs up please.
Hope your back to full suction soon. :)
Hi there it's SmartAlec from NelsonVacuums.com.au here. It is very likely you have a problem in the radix assembly or the filter is actually worn out. Basically to test either simply remove one then turn it on to test. If it runs better with out the filter (washable is most likely culprit) simply purchase a new one. If it is the radix assembly that is the problem it is possible to clean inside the little tubes by taking off the top and literally clearing dirt and fluff out with the help of a coat hanger. Alternatively a new one can be purchased. If you are in Australia or New Zealand I can help you with either part. Just put in a request via the email link n our website. Hope this helps regards Alec
Not absolutely sure about this, so your feedback will be very welcome.
What follows applies to the DC14, which I think is similar in this respect:
Stand behind the machine, holding the handle at a 45 degree angle. Locate and remove the airway inspection valve (bottom of handle, right side). Where the valve plugs in there is a square plastic moulding that should slide up and down. Snap that square plastic piece up towards the ceiling. After it snaps into place, the machine should stand upright.
Good luck, and please let me know how you get on!
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Check the sole plate where the roller brush is. There may be an obstruction leading from the sole plate to the main dirt channel. Usually on many Panasonic uprights the main dirt channel is a removable bent plastic tube before it meets the bottom of the hose. Check to see if this isn't obstructed. ALso check your filters on the vacuum as sometimes a blocked filter means a lack of suction.
Make sure you have a filter installed, then change or clean it. Without a filter, the fan will get clogged.
If that doesn't help, clean the fan and the exhaust port, and verify that the fan is working.
If the fan is working and the filter is clean, then your appearent lack of suction is probably due to the fact that your brushes are not turning, and therefore not collecting debris. That's a whole different problem, one I also have, but haven't solved yet (though there are suggestions on this site).
