Question about HP PSC 950 All-In-One InkJet Printer
Printing problems ive just changed my ink and my print come out with a rainbow effect what can i do.......thanks
  • Anonymous Jun 30, 2008
    changed color ink cartridge and printer is not printing
    Scholar:
  • 94 Answers
Hi, Asside from aligning the printhead you can also try head cleaning and nozzle checking. On that way we can identify what have caused this issue.
---->> Tirzo
Posted on Jun 11, 2008
  • 81 Answers
There should be a procedure to align the print heads. It sounds as though they are out of alignment.
Mp630
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 04, 2012 | Office Equipment & Supplies
How to change cartridge after ink has dried
Changing the ink cartridge is not the only problem, the print head will need to be changed as well.
Jun 20, 2011 | HP DeskJet 3745 Printer
Epson stylus dx4000 printing blank pages . how do
replace cartriges, clean printers heads from utility menu
Oct 25, 2009 | Office Equipment & Supplies
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Coloured lines on print outs
hi,
replace your cartridges with new one . it is cartridge head problem
Aug 20, 2009 | Office Equipment & Supplies
Printer will not print anything. Ink levels are
If it has been longer than 3 or 4 weeks since anything last printed, the problem may be clogged print heads. Run thru several cleaning cycles and see if anything begins to appear on the paper. If not, changing the ink cartridges may solve the problem. If it's been quite a long time since last printing, you may need new (and expensive) printheads. If that's the case, replacing the printer would be more cost effective. Sorry for the bad news.
Aug 13, 2009 | Epson Stylus C88 InkJet Photo Printer
Vertical banding (rainbow effect)
You need to scan the prints at the same resolution that they were printed. Otherwise you'll get that screen door effect (moire pattern). I think this effects most scanners. I'm currently looking for a photoshop solution to this problem since I don't have the originals. Not fun.
Jul 14, 2009 | Epson Perfection V350 Flatbed Scanner
Faint rainbow line of blue/orange/yellow at end of printed photo
You might try cleaning or unclogging the print head[s] with a drop of water or two onto the outlet from the print cartridge[s] and a drop of water or two onto the inlet orifice into which the outlet of the cartridge feeds the ink.
May 18, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon i550 has has rainbow line in output
Even though you say you have ink, the "rainbow" line is usually an ink problem. Try doing a head clean process.
Right-mouse click on the printer and bring up "Properties". There should be a 'Maintenance" tab and one or more cleaning options and/or nozzle checks.
Sep 05, 2008 | Canon BubbleJet i550 InkJet Printer
I have had the Deskjet D4160 for over a year, now for what ever reason, the printer will not print. I have tried all of their suggestions. Restarting the computer, disconnecting the printer. I have been...
I was using the printer, wanted to change to a color ink cartridge. Upon changing, the printer made some weird sounds then didnt print. Changed back to original black ink cartridge and still wont work...Ive done everything that I can find to eliminate the problem but still wont print. Any help would be GREAT Thanks
Jun 24, 2008 | HP DESKJET PRINTER, HP OR COMPATIBLE
HP PSC 950 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
