Question about Zanussi ZWF1630 Front Load Washer
Zanussi washing machine wjd1357s
My machine blows the fuse when trying to heat the water. How easy is it to change element.
Regards brian Cummings
  • Anonymous Jan 26, 2009
    i need to replace the control panel on my zanussi washing machine but do not know how to remove the used one?
    Champion:
  • 249 Answers
Very easy
Posted on Jun 11, 2008
How hard is to replace a heater element on a BEKO wm5140s washing machine! cheers Brian
Fairly easy.disconnect mains drain any surplus water via drain bottom front of machine.access to the heating element is from below so tip machine from one side against wall at45degrees.... I normally use a towel on bottom edge to stop it sliding whilst I unscrew any bottom plate.you will see the heating element housed at the base of drum unit.disconnect wires and unbolt or unscrew element housing .youtube has tutorials on this but many machines are similar in thus respect.good luck
Jan 29, 2015 | Beko Washing Machines
Machine cutting out and blowing fuse
if its the rcd tripped in mains then you have a current leak to earth. means water or steam has tripped . u need to find source in washing machine, often the heating element or thermostat..u could look for free service manual at manualslib ManualsLib Makes it easy to find manuals online
Jul 14, 2014 | Siemens Washing Machines
Washer skips rinse cycle
Possible defective washer control panel.
Jul 13, 2017 | Zanussi Washing Machines
I have Zanussi DX6453 dishwasher. Suddenly it is not drying our dishes. All programs working. Do you think is problem with Element or Thermostat. It is heating water.
sugget the water temperature, it relies on the temperature of the water to heat to items up so that when the wash cycle has finished the heat will dry them. Hope this is useful. Regards Mike
Jul 07, 2011 | Zanussi Dishwashers
How do i replace heating element in a zanussi washing machine
Hi.
It depends on the model of washer.
If it has no removeable rear panel, then you have to remove the complete rear half of the cabinet to access the heater, not an easy job.
If it is an early model, then it will have a removeable rear cover, and the heater can be changed from the rear of the washer.
Feb 12, 2011 | Zanussi Washing Machines
No power to my washing machine (fuse changed still no power)
hello, have you checked the glass fuse inside the power supply if it has blown make you use the same rated fuse if it blows again the you have dead short in the washer somewhere hope it helps
regards
shaun
Jan 03, 2011 | Zanussi FC1200W Front Load Washer
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
Feb 15, 2009 | Zanussi IZ12 Front Load Washer
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Zanussi WJD1667W not drying at all
I've got this machine, and all washer dryers tend to have two heating elements and it sounds to me that the heating element for the drying side of the machine's functions needs replacing. You could probably find a cheap element for the machine somewhere and get it fitted for a small sum.
Let me know if this rectifies your problem
WD Pro
Apr 24, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
Open Questions:
Zanussi ZWF1630 Front Load Washer Logo
166 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
