Question about Sunpak DX-8R TTL Ring Light Flash
Sunpak ring flash problem
I have a auto DX12R and am having problems. Its very tempremental and fires sometimes but will not work at all on other occasions. I am using normal AA batteries rather than the AC connection. Can you help?
  • 4 Answers
I had a DX-12R for some time several years ago until it was stolen. I loved it. I recently purchased a used 8R and it is fine but I still like the 12R better. Especially the preview light feature. Ok. Make sure the batteries are all good, one bad apple does spoil the whole bunch. Check your cord connections and finally make sure the hot shoe connection is clean. That last one was usually the culprit when I had problems. Note that your hot shoe on your camera could also be going bad. I had a Ricoh that did that, I thought it was the flash. Good luck.
Posted on Sep 18, 2009
  • Jim Aug 19, 2011
    Late reply I know, but I was given a DX-12R but the bulb is no good. I have looked and I cant find a replacement for it. Anyone know where to find them?
    thanks
Hi, I have a Sunpak Auto 555 that can be turned on but refuses to fire! Is is possible that I need to change the flash tube? Does anyone know where to buy one?
When it is not triggering either Tube is dead or Trigger circuit has a problem. You can get junk flash from Ebay.
Oct 26, 2017 | Sunpak Cameras
I need a operating manual for Sunpak Auto Thyristor G4500DX Flash gun only
I found this for a Sunpak flash which is similar to the G4500dx:
Reading from the "auto555/G4500DX" Manual, you need to:
1. Slide the Film Selector to desired ISO - (that is the same as your camera ISO used - so, make sure you turn Off the Auto ISO feature if your camera has one).
2. Slide the Mode Selector to "A" (Auto position). This will be Auto Thyristor mode on the flash.
3. Slide the Auto F/stop Selecct Know to desired lens openning - ( so use your camera in Aperture priority mode, more in Manual to prevent changes in the camera aperture value during shooting)
Shoot, and be happy with well exposed pictures by the Auto Thyristor features of the Sunpak 555 flash.
The Sunpak 555 works great with Nikon D50, D70 cameras, as you can synchrinize flash practically at all shutter speeds. Excellent for sunny days to get narrow DOF, yet get any ambient light level contribution as desired.
For other cameras, make sure (watch out for) that Aperture Priority mode does not use shutter faster than the camera max X-sync speed - so Manual camera mode could be a better choice for a novice photographer.
In the manual there is also a list of accessories for various brand cameras, How to use Power Ratio in Manual mode, some advice on using wide lenses, how to care of your 555, and Specification section.
Minimal flash duration is 1/450 at full power, so you can safely use Auto Aperture up to 1/500 sec. Flash duration decreases with lower power setting, or lower auto mode need for poser, and the shortest flash duration is 1/17000th sec.
Jan 29, 2016 | Sunpak Cameras
Using a Sunpak 555 with Cybersync transmitters with a canon 40D off camera and getting inconsistent firing
did you find a solution? ive experienced a similiar problem. i think i might need to buy new flashes.
Aug 13, 2012 | Sunpak Auto 555 TTL Flash
How does the Sunpak Auto 555 Thyristor Flash Unit work concrning a battery? Does it always need the ourside battery pack unit also?
When internal cells are fully charged it do not need external ones
http://www.photographyreview.com/mfr/sunpak/flashes/PRD_84012_3121crx.aspx
Aug 07, 2010 | Sunpak Auto 555 TTL Flash
My Sunpak Auto 383 Super will not fire on or off the camera. When I turn on the switch, the ready/test light lights immediately. I suspect the bulb is burned out, so I wonder if that can be replaced.
There can be one of many parts which is gone :
Flash tube,capacitor,trigger cap.or triggering switch.
Warning as it has 330 volts even when battery is removed do not open if you are not aware of the risks.
Sunpak 383 contains no bulbs inside.
Feb 21, 2010 | Sunpak 383 Super Flash
I have a sunpak 622
Sunpak does not offer dedicated (TTL) module to any digital cameras. The flash can only be used in auto mode, while the camera is set to full manual. The lens has to be stopped down according the working aperture on the flash, correct exposure will be maintained by the built-in sensor of the flash. Fire the flash using a simple hotshoe-to-PC cube if your camera doesn't sport a PC connector. Trigger voltage of the 622 is safe.
Jan 31, 2009 | Sunpak 622 Super Pro TTL Flash
Flash works intermittantly
There can be more than one causes.
If intermittent work mean that in, at least, some cases the strobe fires normally and the internal sensor controls the power as it should, then the most probable cause is a diry contact at the either end of the PC cord or a broken wire in the cord. Clean with any gentle method or disconnect-reconnect a dozen times in order to rub off the oxidization, or replace in the latter case.
If it doesn't help then the culprit can be a cold solder joint inside the flash, the repair of which asks for a technician with skills.
If the intermittent work means that the flash always fires, but sometimes with the correct power and sometimes with full power, then the case is more sophisticated, and surely needs a repair of internal circuitry. See the description of such issue for a Sunpak 522 elsewhere in Fixya
Good luck, Laszlo
Nov 16, 2008 | Sunpak Auto 544 Flash
Sunpak 522 and 544 always firing full power
Try cleaning that front flash sensor.
Alexander
atdlee@netzero.com
Dec 13, 2007 | Sunpak Auto 544 Flash
Sunpack DX-8R
You will need the proper module. Check with B&H photo for the module compatable with your Olympus camera body.
Nov 26, 2007 | Sunpak DX-8R TTL Ring Light Flash
Sunpak DX-8R TTL Ring Light Flash Logo
618 people viewed this question
Top Sunpak Cameras Experts
bhargav
Tony Parsons
Tony Parsons
Neal Marrison
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
