Question about Canon ZR200 Mini DV Digital Camcorder
Gray lines across screen
Gray lines showed up on the screen out of nowhere. when I download video to my laptop gray lines are downloaded also. Checked different tapes and still gray lines so it's the camcorder, not the tape.
one thread on this website mentions changing resolution. ok, so how do you do that?
  • tallixr Jun 30, 2008
    I have the same issue with just one tape. My wife turned the cam on and was trying to do a plyback, but failed miserabley! Instead pressed something in the main camera menu. Now when playing this particular tape back, it has thick grey bangs runnung from side to side.
  • Anonymous Oct 17, 2008
    I have the same problem and the camera is out of warranty!
  • 979 Answers
You have a "head clog" more than likely...accordianman
Posted on Jul 02, 2008
HP laptop screen is gray with vertical lines
Hook a monitor to the video output, if the system is the same the problem is in the video graphics chip on the motherboard.
Jul 23, 2012 | HP Pavilion G60-249wm Notebook
Screen turns green and red lines appear across
my HD LCD used to turn grey on my 360 so i just turned it off then back on for the results but of coures it could be the LCD is dying
Dec 28, 2009 | Microsoft Xbox 360 Console
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
The lcd screen is gray with black bars across it in every mode.
Could be you ccd, charged coupling device, eye of camera. May be pricey to repair. go to panasonic on line for quote
Apr 15, 2009 | Panasonic PV-GS31 Mini DV Digital...
Lines across the sreen when i play back the tape
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off.
Nov 25, 2008 | Canon ZR800 Mini DV Digital Camcorder
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Gray lines across video screen during playback
my canon zr 200 in playback is fine but when i turn it on to record i have multi colored bars on screen and wont record
Jan 06, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200 Gray lines
Change your resolution and it should go away.
Dec 17, 2007 | Canon ZR200 Mini DV Digital Camcorder
Gray bars across the screen...
try to clean the video head using a blank new tape just forward it 5 times as need...do not use video cassette cleaner cause it too rough for the head....check the head if there no crack on it....if nothing you find it is time to replace the to the service center...
Jul 27, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Canon ZR200 Mini DV Digital Camcorder Logo
430 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
