Question about Sharp Office Equipment & Supplies
Sharp AR-5020 - constant paper jam
Sharp AR-5020 with constant paper jam
  • 2072 Answers
SOURCE: Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Posted on Mar 17, 2008
mickspaceNET
  • 115 Answers
SOURCE: Printer constantly paused during printing
Is Post Script Key in the Mahcine? (PS must be intalled on the machine)
Do you have the Correct Driver
www.sharpusa.com
Posted on Oct 23, 2008
  • 22 Answers
SOURCE: SHARP AR 5020 error F5-02
you reset your eror code program c#0#
Posted on May 30, 2009
  • 990 Answers
SOURCE: my Sharp AR M205 has the error H4
Hello sir; Your machine require reset procedure; press "#", "interupt", "clear", "interupt" then enter 14 press start.
Posted on Jun 04, 2009
  • 46 Answers
SOURCE: Constantly getting paper jams
where the paper comes out there is a rubber roller that roller must be cleaned to get to that roller open the back cover then you will see the fuser cover that cover just drops down then you will see a white plastic remove that plastic by removing two screws at each side of the white plastic you do not have to open the rear part completely that white plastic sould come out if you wiggle it a bit you will have to take it out one side at a time then when that white plastic is removed you will see the rubber roller just clean that roller with benzine or alcohol. The machine gives you paperjams because that roller gets sticky over time.
Posted on Oct 29, 2009
My copier keeps tearing papers.
Paper tears due to the following;
a. Improper paper size on tray
b. Putting excess papers on tray
c. Dirty feed rollers
d. improper jam removal
Rectify the above.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a Sharp AR-164 copier I have removed the paper jam cleaned everything out and it still says I have a paper jam how can I reset the copier??
turn power off, then back on. there might be a small piece of paper still blocking a senor. look down the middle very good.
Nov 03, 2009 | Sharp AR-164 Copier
May 30, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
Apr 01, 2009 | Sharp AR-275 Copier
SHARP AR5320 error F5-02
SHARP AR 5020 error F5-02 pls canu give some tips very helpful its urgent sir
Dec 15, 2008 | Sharp AR-5320 Black and White Copier
Pages come out black
It could be toner build up on the fuser rollers. If the jam was pulled from the fuser section.
Where was the jam at?
Nov 20, 2008 | Sharp AR-M237 Digital Copier
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
PAPER JAM
Did not specify where it is jamming?
is the paper size correct?
is the paper under the metal tabs in the tray?
is it jamming in the fuser?
is the fuser OK, if constant jamming in fuser then replace.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
