Tv stuck in standby
I have a Thomson tv, model 32wf400 g, the television is stuck in standby. When I turn the system on it will try to start up and it keeps clicking and the light changes from red to the orange start up but than back to the red. It will not get out of the standby mode. Can you tell me why, and how do I fix it? Exact same problem with a Memorex MT2025, especially the "clicking" sound. When I turn the system on the power light will turn green immediately followed by about 1/2 second of clicking, and then it goes right back to standby. The TV is only 5 months old, and replaced a Magnavox I had for 26 years.
  • Brian
    Brian Jun 14, 2008
    I'll give that a try and let you know.
    Thanks!
  • 58 Answers
Your problem is in the switch mode power supply or the horizontal out circut.
sometimes the small CHOKE that feeds the base of the horz. out transistor has a cold solder joint.
resolder both ends first.
Thanks Guy9
Posted on Jun 11, 2008
My Thomson Intuvia 32 does not turn on?
i think you have a fault in the standby power board.
a kit is availalable for this and can be obtained from www.tvs-services.com or cal 01245392539 monday to friday 9 to 5
Feb 19, 2010 | Thomson Televison & Video
I have a LCD TV THOMSON 32lb040s5, the problem is that the TV start and turn off again and again when I start it
you probably have a fault on the stand by power board.
this normally requires soldering and maybe some componet changes. This is not a job for the unskilled. best carried out by a service engineer(shock hazard)
there is a service kit for this available from tvs-services.com 012453925
Jan 18, 2010 | Thomson 32LB130S5 32 in. LCD TV
Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Jan 15, 2010 | Thomson LCDB 03B 27 in. Television
It wont turn on its stuck on stand by any suggestions? when we do get the tv turned on we cant knock it off or it takes hours of fiddling with the remote standby button to get it back on the tv is a...
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Let me know if you need more help or info.
Nov 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
Thomson 32WZ610s television stays in standby
It the power inverter supply board 90% of the times.Very comon with LCD tv's design flaws in power inverter boards.Many,not all use the
same designs.
Aug 24, 2009 | Televison & Video
Thompson 52jw643 is stuck in standby, when switch on red led appears, changes to yellow for approx 1-2 sec, sounds like trying to start and reverts to red. sometimes flashes red once. any help greatfully...
I have a similar problem with Thomson 52JW643 S in that it takes at least 12 to 16 attempts before it eventually turns on very very annoying !!!!!!! turns from red to yellow to green then back to red and then same again until she feels like switching on then perfect picture sound and quality ??????? can any one advise please
Jun 27, 2009 | Thomson Televison & Video
Thomson 44jw642s problem with starting.
Verify capacitor cp150 (2200uF/16V)
JLopes
Oct 26, 2008 | Thomson Televison & Video
My sharp 26"lcd tv stuck in standby,wont turn on
I had a same problem with sharp LC-40LE340E. The service told me to change motherboard but I decided to buy a new LG TV. The sharp TV I left unplugged for a 50 days and after that when I tried again the tv started normally. I was Really surprised. Don't spend money just wait and check again. shkelzen65@gmail.com
Oct 12, 2007 | Sharp LC-65D90U 65 in. LCD Television
Televison & Video Logo
599 people viewed this question
Top Televison & Video Experts
Electro Med Services...
