Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Hi! I tried it and was unsuccessfull
Hi thanks for the advice but I found the hose, blew through it tomake sure it was clean and air flowed through to the inside of the washer. I then re-connected the clear tube to the level switch . When I turned it back on..still over filling! Im not sure what to do now..You got any idea? Please let me know..Thankyou so much
  • Tanz Ili
    Tanz Ili Jun 11, 2008
    how much would you estimate for the replacement of the water switch.
  • Tanz Ili
    Tanz Ili Jun 12, 2008
    Thanks will do!
  • 413 Answers
At this point, the water level switch will have to be replaced.
Posted on Jun 10, 2008
  • Richard
    Richard Jun 12, 2008
    The switch sells for about $30.00. Before replacing.. check the pressure hose for any cuts, tears or pinholes.
Hi , i have a problem with a plasma LG 42PX3RVA, the set turns green when you press the power button but no picture or sound , i measure the voltage on the boards and found thay it was correct acco
Bulb overheated and probably blew, they are made of mercury most times so don't touch them they should be in a housing, that could be it. If most times dust gets in there and the fan gets weighted down with dust if its up against the wall no air flow, so there ya go, try that. good luck
Jun 02, 2014 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Dryer heats up and finishes cycle, but clothes still damp. It actually smells like something is burning. I already checked and redirected the hose, blew the pipe leading outside, cleaned the filter and...
check air flow were heat exhausts outside. good air flow? sounds like lint clogged. couuld be in dryer, in exhaust hose, id start with hose make sure clear and not kinked.
Mar 10, 2014 | LG DLE2532W Electric Dryer
I have a 2007 XR 650 L. Out riding with some friends. The power dissappeared and riders behind said a lot of smoke out of exhaust! Temperature on my Vector went out of sight. Thought I blew something,...
Hi and welcome to FixYa!
It's better if you can replace the hoses. Piston rings are surely worn and needs replacement. I strongly suggest that during these cases an air valve replacement is much recommended.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 26, 2011 | 2005 Honda XR 650 L
I own the 10685, mowed 6 times this year and on the 7th out of nowhere it developed a problem. Primed as usual, starts, runs about 30 seconds, quits. If I catch it in time I can hit the primer again and it...
Just a suggestion O.K?
Carefully check the small fuel lines. To and from the bulb. Make sure the bulb fills with gas.( at least two thirds full. ) There is a small fuel filter on the end of a small fuel line in the tank. A small hook of stiff wire will dig that out. Good luck !!!!
May 14, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
MY SIMPSON MAXIDRY 362 3.5KG HEAVY DUTY DRYER KEEPS OVERHEATING AND CUTTING OUT. WHEN IT STOPS AND I PRESS THE SAFETY SWITCH IT TURNS ON AGAIN BUT ONLY FOR 10 MINUTES. CAN YOU ADVICE ME ON WHAT I CAN DO...
I would check the exhaust pipe outside and make sure it is not blocked and has good strong air flow while the dryer is running. If there is not good airflow, then clean out the exhaust hose and pipe. There could be other problems, but I would start with this.
May 01, 2010 | Dryers
Furnace comes on Lo but no shift to High. Fan does not come on.
There will be a separate pressure switch for hi fire, make sure all hoses are connected and free of moisture and debris. You can temporally jump the switch once the inducer fan speeds up, not before. If the unit fires on high, you have a pressure switch issue. If the fan does not speed up, you may have a bad relay on the control board. If the unit is just being put into winter service, it may have a cob web restricting gas flow to the burner. You will need to check the air inlet as well as the exhaust pipe for restriction. Check on the wiring diagram to make sure that the DIP switches are in the proper position, you never know. Hope this helps.
Dec 10, 2009 | Heating & Cooling
Bissell Pro Heat 7901 will spay through hose but not the floor and red flow indicator will not spin. So we took the housing off and after unclogging a hose running to the hearter, my husband unhooked the...
I borrowed my friends bissell to clean my carpet. It's the 7901. He brought it over and told me that it only sprayed out of the attachment hose. He said he couldn't figure out what was wrong. I'm no vacuum technician but, I am a mechnic. I decided to open her up and check it out. After about two hours it was back together and working. The reason I replied to your e-mail was because we have the same problem. I couldn't find an answer to this problem on this site so I will tell you what I found and hopefully it will help you. In removing the cover where the red heating light is, there is the heating unit for the water. In my case it is silver and it will get very hot so be careful. Notice that there is two water hoses connected to it. I removed this heater and found one of the connectors where the water hose goes was clogged. I took the back off the heater and used my air compressor to blow out the connector, and sure enough something flew out. Hope this helps. brian.small@bobstgroup.com
Sep 04, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
FAN ERROR BUT THE FANS WORK
There are air flow sensors in the unit as well which you may have blocked up when you blew out the fans. If those sensors do not detect air flow, the assumption is that there is a fan error. Try removing the fan and cleaning the entire air flow path.
Dan
Aug 26, 2008 | Toshiba TLP-S10 Multimedia Projector
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
