Question about Casio Computers & Internet
Piano/keyboard won't work through imac
Tried to connect a casio ctk-571 keyboard to an apple computer through the headphone output on the casio, into the mic input on the computer, It didn't work. Do I need to download a driver for it, or get a usb midi cable?
  • wedie Jun 12, 2008
    I'll try buying the midi cable, that should work hopefully.
    Thank you for your help.
    Scholar:
  • 82 Answers
Try to connect to other input lines. If your computer has an input line except for mic input try to connect to it. Then configure the settings in your computer, go to the CONTROL PANEL on your computer click SOUNDS & AUDIO DEVICES then configure SOUNDS or AUDIO or VOLUME or VOICE. Then look for the device listed in your system that is available and compatible, then select the most appropriate. After that click APPLY then OK. There you go.
If this solution Doesn't work you must buy a sound card and for sure it will work. Having a sound card gives you several input lines and there is a particular input line for musical instrument like a keyboard in a sound card device. Installing a sound card is easy, and i'll show you. First you must insert your sound card device into your motherboard's PCI slot (most of the motherboards have 3 PCI slots) choose one and take note that your PCI sound card plugs in exactly in that slot so its very easy. After inserting your sound card install the driver for your sound card, install is easy just follow instruction. If you have done this, there you go.
Good Luck!
Pls. rate me if this helps.
Posted on Jun 12, 2008
Why does my keyboard have no sound?
Try using headphones. If it works, then you have a problem with the speakers if you have built in's.
Jan 20, 2016 | Casio Ctk-5000 Electronic Keyboard Piano...
Piano Rhythms not playing in casio ctk 7000
some rhythms have only accompaniment in it. This is not a malfunction I think. And What about this ? This is my problem with casio ctk 7000.. Can you try on the keyboard ? : Hello. I bought a Casio keyboard CTK 7000 two months ago. Firstly I did not notice the problem. But a few days ago I perceived this malfunction; Sometimes when I hit the "INTRO" button during any default (Not user) rhyhms and accompaniment plays, the playing chord is jumping to C chord. For example; When the accompanimet is playing Am chord and I push the "INTRO" button, the keyboard changes the "Am" chord to "C" chord automatically. It always happens when I hit the INTRO button at the just beginning of the measure but not at the middle of the measure. Its troublesome for me, specially during live performance. Can you help and give information about this problem? Thank you very much already now.
Nov 22, 2012 | Casio CTK-7000 61-Key Keyboard CTK7000
Casio keyboard ctk 2100 won't turn on
Do you have dead batteries, remove and use the adaptor only - try again.
Oct 21, 2012 | Casio CTK-2100 - 61 Key Portable Keyboard...
When I plug in stereo headphones in the casio wk 210, the sound only comes out of one ear. I didn't really care about that before, but now when I connect a line out from the piano to my computer to...
The output of the casio may only be mono, you can buy splitters to create a 2x channel output. Is there any other outputs from the casio other than headphones, usually there are red/white RCA outputs (Phono's) which would be better for connecting to your soundcard.
Hope I was of use to you, good luck.
Aug 04, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I have connected my casio to pc but pc songs and piano sound is not hearing in pc how it will work if any driver will use tell me about that i have casio ctk-2100 electronic keyboard
ASSUMING you have a MIDI interface connection, (not audio) then you need to set the PC to use a general MIDI sound and turn on the synth in the PC.
Go to control panel and open the sound icon. Select the device to use for MIDI playback in the appropriate section.
Sep 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Nov 30, 2009 | Casio Music
How can i connect my ctk-720 to my mac & the garage band application.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Nov 28, 2009 | Casio Music
Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Apr 04, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio Ctk 496 Electronic Keyboard with 61 Keys, drivers needed
Try uninstalling and reinstalling both the keyboard and the game. If that doesn't work then the keyboard may not be compatible with the software.
Dec 30, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Computers & Internet Logo
382 people viewed this question
Top Casio Computers & Internet Experts
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
