Question about Toshiba Computers & Internet
My laptop is keep seazed up - Toshiba Computers & Internet
  • 100 Answers
Scan the entire harddrive or format o.s and install o.s
Posted on Jun 10, 2008
What issues can I expect if it doesn't restart?
If the belt broke you are facing bent valves in the cylinder head. If the vehicle is single over head cam.... bet on bent valves. If the vehicle is dual over head cam ... you may be ok. The dealership should be able to perform a cylinder leak down test to determine whether or not the there is a valve issue before disassembling anything.
Mar 01, 2016 | 2007 Chrysler PT Cruiser Touring Hatchback
What is the problem with a 1999 Mercury Sable that is over heating, losing water and the serpentine belt is not turning
belt tensioner is seazed or a pulley is seazed so belt wont turn or belt needs replacement as groves are worn out. the over heating could be your thermostat
Sep 17, 2013 | Mercury Sable Cars & Trucks
Admiral HMG61139 21.1 cu ft Side-by side refrigerator, not cooling. clicking sound every few minutes. (sounds similar to oven thermostat or relay coming on).
Thier is one of a couple things going on with your refrig.
The start relay on the compressor is bad so what your hearing is the overload thermostat tripping on and off and keeps trying to start the compressor
The fan motor by the compressor called the condenser fan motor is not running to cool the compressor so once and what you overload keep trying to start the compressor but its too hot to start
Finally the compressor is locked up and the overload still keeps trying to start it but its totally seazed and ain't going to run
I hope this helps you to determine what is wrong with your refrigerator,
Gene
Aug 10, 2011 | Admiral 26 cu. ft. Side-By-Side...
The car wont start ,the battery is fully charger,wont crank or turn
Is it a manual transmission model? If so, you might want to check the fuse activating the clutch-in start. Mine blew and all it takes is a simple fuse replacement :-)
Aug 16, 2010 | 1991 Honda Civic
Air conditioner blowing warm air in saturn ion
if the AC is blowing worm air you need to get your AC recharged if you have alredy done that you should get the compressor checked (it sometimes seazes up or the cluch on it will seaze and you will need to replace it
i hope this helps
Aug 06, 2010 | 2006 Saturn ION
My ac has quit working and its fully charged just not getting cold what could the problem be?
first thing to check is the fuses and relays to see if there working rite (have a friend press the AC button and lisen for a clicking sound if you do the relay should be working (after your friend pressed the button if you here constant clicking or no clicking you should replace the relay
if your car has a fuse check the fuse with a multy meater if its bad replace it
the clutch on the AC compressor might be seazed this can cause the compressor to not funtion (this happens usually deuring winter months because of the lack of use )
the compressor its self might be seazed if so you should get it replaced
i hope this helps ^-^
Aug 06, 2010 | 2000 Pontiac Grand Prix
Steering seazed up
The hydraulic power assisted system of the steering system is out of order !
Feb 16, 2010 | 2002 Audi S4
Short time compressoe run
Sounds like compressor overload is tripping. Check for burnt wires and bad capacitor. You may need to take cap to motor shop to have it tested. Cnpressor may be seazing up or overload could be weak. If it has a low pressure switch it could be low refrigerant. There are a lot of things to cause short cycling. If compressor kicks back on on its own and repeats this process then it is most likely drawing high amps for one of the above reasons. I'mthinking it is seazing up as bad capacitor or burnt wire most likely wouldn't let it run in the first place.
Jul 04, 2009 | Kenmore 75085 Air Conditioner
Key board not writing as stated
liklely dust on ur keyboard, use a blower....
Apr 02, 2008 | Dell Latitude CPX650 Notebook
uninstall keyboard drivers from device manager and click scan for hardware changes automatically it will take drivers,again same problem will come attach the external keyboard and check if work keyboard problem on laptop
Mar 11, 2008 | Dell Latitude C640 Notebook
Computers & Internet Logo
14 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
