Question about Nokia 3110 Cellular Phone
Master code for all nokia 3110
Sir can i get the master code for all nokia 3110.
  • 3 Answers
Nokia Unlock Codes, Nokia Phone 3110 Secret Codes, Cell Phone Codes
Nokia 3110 Secrets
*#06# : Checking the IMEI (International Mobile Equipment Identity)
*#7780# Restores Factory Settings (Memory, language, counters are not included).
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#746025625# [*#sim0clock#]
Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#92702689# [*#war0anty#]
Press the following warranty code :
6232 (OK) : Displays the Month and Year of Manufacture (0997)
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
Service Prover Lock
The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it. The cell phone will however accept another SIM card from the same operator. All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove SIM card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
NOTE : These codes could be used with care. A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful!
Bypass the SP lock
With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIM locked to one provider you can bypass the SP lock like this:
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key.
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again.
NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #.
The 54# Tip:
Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed
Posted on Jun 10, 2008
I have forget my password so please help my mobile IMEI no is 356852029787086 please send me immeditly to my email id (vigneshwar.vs@gmail.com)
If you forget the security code means get the master reset code for your nokia mobile, because does not remember security code you have to reset your mobile its a only way to use the mobile, so get the master reset code for your Nokia 3110 model mobile from this site Onlinegsmunlock.com, it has the best services for the master reset code for your nokia mobile.....I hope this may helpful to you.........
Aug 11, 2011 | Nokia 3110 Cellular Phone
HELP PLEASEEEEEEEEEEE my nokia 3110 claassic phone is locked, ive forgot the sucurity code, 353081024980016 heres my imei, i cant fix it :((
sir if you forgot the security code, You have to master reset the phone. Contact your service provider to get a master reset code at free of cost....You can also visit http://www.unlock-zone.com/ and can see different options there to get unlock code for a price. Choose any price appropriate for you.................
Jan 06, 2011 | Nokia 3110 Cellular Phone
Sir how to format my 3110 to restore all problem on my cellphone what is the key words?please tell me thank you
try to enter *#7370# to hard reset your 3110 or *#7780#. type 12345 when asked of the 5 digit code. this may work for your cellphone.
Nov 01, 2010 | Nokia 3110 Cellular Phone
I forgot my security code for my nokia 1280, how do i reset the phone
i forget my security code 4 my nokia 1280 and i want to open it back i need master code pls
Oct 03, 2010 | Nokia 3110 Cellular Phone
Nokia 3110c mobile, i forgot security code.now how
Sir i have Nokia 3110c mobile, i forgot security code.now how to reset security code?
Oct 27, 2009 | Nokia 3110 Cellular Phone
Security problem
Nokia phones do not have a master override. Once forgotten the phone will need to be replaced. You can also try the default code which is 12345.
Sep 12, 2009 | Nokia 3110 Cellular Phone
Master reset code for my nokia 3110c
Hi Friend,
Kindly note down the master security code as follows,
5011615732
or check it in the below link
http://mastercode.nokiafree.org/
Kindly and revert back
Regards,
Ayyasam
Jun 07, 2009 | Nokia 3110 Cellular Phone
About security code
Hi, musyawie55
country: Brunei IMEI: 355728025491884
your master reset code is:
7211475210
Sep 19, 2008 | Nokia 3110 Cellular Phone
Master code pls
Sir yesa koi softwar aata hai kya jise ki mobail ka pata kiya jaa sake kyun ki mere bahut se seat kho chuke hai agar sir yesa koi bhi softwar hoto hume softwar kaa name bata sakte hai kya plz.... sir rikuyeste hai mi mail is esh_242@yahoo.co.in
Apr 02, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
671 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
