I have a Sharp Aquos T.V. and right now the picture is fine but there is no sound coming from the set. I have checked the cables and they seem to be all right. I cannot imagine what could do this. I rarely watch this T.V. and bought it about 2 l/2 yrs. ago
  • SCOTT J May 11, 2010
    please provide the model# sharp does have an know audio problem that they should cover if you call them - once i get the model # ill let you know - if you are one of the lucky - if they wont cover the fix is easy (do not change the main processor)
    Novelist:
    Champion:
  • 203 Answers
I ran into this problem on two of these sets and it turned out to be a heatsink which is located beneath the main p.c.b. What happened is the putty that they use as a heat transfer compound melted and in turn the heatsink slid down and touched the main p.c.b. causing a no sound condition, or intermittent. There are a hundred screws and major disassembly/reassembly required so plan on spending a half a day. You may find an open resistor or burnt surface mount component on the board so take your time before reassembling and look for burn marks on bottom af board. As I recall there are two boards that have to be removed just to get at main board and then you pull it out to reveal a metal heatsink not secured to anything. Good luck, your welcome, Russmann.
Posted on Jun 11, 2008
    President:
  • 1,284 Answers
Try unplugging the TV for 2 minutes and then re-trying to power it on again and see if audio returns. Is this connected to a cable box and other types of inputs? Make sure if there is a speaker on/off function in the menu that it isn't set to off. Also can you give me a model number so I can look up part numbers if needed.
  • 58 Answers
A lot of thes sets develope audio or intermittent sound problems
I discovered the problem is in the main processor board and SHARP does not want to warranty these sets in CANADA. not sure about the U.S.
sorry
Guy9
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Picture and sound go out on my 60" sharp aquos tv
Check its sound settings first. If it is OK, check its speaker. If you wish to get more details about these type of faults, check this link. Pull up older posts there.
Mar 20, 2013 | Sharp Televison & Video
We have a new 46" Sharp Aquos with a "snowy"
sounds like you have a cable connection problem make sure your tv is set to dtv signal in the menu screen. when you scan the channels should be displayed as 12.1 or 8.2 not just a single number if the digital channels are programmed correctly then change the cable coming into the tv from antenna making sure that it isnot crossing any power wires good luck and hope that i helped
Nov 07, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
Feb 08, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Picture but no sound on two cable channels. All
Make sure under the Audio Menu that you have SAP turned OFF
Jul 09, 2009 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Sharp Aquous will not turn on.
I would check the System Cable that is linking the box to the TV. Then, press the small button called CLEAR in the front of the box. The button should be behind the flip cover on the front right below the PC input ports.
Let me know if this solution works.
Jun 01, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
No Picture
I doubt that your component has burned out. You may be looking at a repair issue here even though your unit is only 3 years old IF: you have tried connecting using different inputs, OR if you cannot bring up your sharp menu, or you list of inputs. If you cannot do those following things, you have a SERVICE issue on your hands and unless you purchased and extended warranty with sharp, its useless calling them. They will just tell you tough luck, and refer you to one of their authorized service centers. good luck
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos 42"
Check the settings in the TV set for HDMI sound on the input of the TV that you are using. Try another HDMI cable. It may be defective.
It is also possible that there is a compatiblity problem for the HDMI sound between the TV and the computer's sound protocol.
Jerry G.
Apr 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC46D64U
No reason for the audio not to work on the RF cable. Check under menu and option and make sure audio is set to fixed and not variable.
Jan 08, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
