Question about Dual XDMR7710 CD Player
Radio Metal Case Gets hot - Not just resonable hot
But makes the CDs hot when ejected. Heres what I have installed in 1987 Cadillac Seville
2 Hot to 2 hot - constant & keyed Ok
Black Ground wire to black gr - Ok
Antennae to antennae - Ok
I do not have the metal case grounded to metal could that do it?
I don't come here often so if you know please email me at:
phreakiphred@hotmail.com
  • Fred Farkelson
    Fred Farkelson Jun 11, 2008
    "use bigger wires."
    I appreciate sarcasm; and I do appreciate people with this natural ability.
    Sarcasm is usually innate; however headman333, if you would still like to attempt
    developing this ability, your chances of success would be greatly
    increased if you were intelligent, or at the least not mentally
    incapable of detecting and reproducing sarcastic remarks. Because headman333 if you cannot make your very own sarcastic comments, you can
    still pass as having some grasp of this art by being able to recognize
    sarcasm when it is produced by someone else, and be able to retain it
    in your memory long enough to use it at a later time when that particular
    sarcastic remark would be relevant...
    Phreakiphred
    Scholar:
  • 82 Answers
Use bigger wires.
Posted on Jun 10, 2008
  • Jimix Eouex
    Jimix Eouex Jul 28, 2008
    Sir i'm sorry i miss the point, you could have do it using metal (chassis) grounding.
How to install this rpm gauge to my gsx r 06
If it's a Chinese gauge the rpm sense wire goes to the ground side of one coil, not the hot side. The red is hot and the green was ground on the Chinese gauge I bought. Do a search on the net under "Wiring Problem with Chinese Speedometer" several good articles on these gauges. The black was key hot and the red was memory constant hot on my gauges. If you reverse them whatever you program will disappear when you turn the key off. Other wires are the rpm sense and the inside light.
May 25, 2015 | Motorcycles
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1984
1985
1986
1987
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness:
1984, 1985:70-1388
1986, 1987:70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
How do u find the ground whire or install a kenwood kac 7205 I found the hot lead but cant find the ground and whats a p supply
ground wire is black. if not able to find put one in yourself. red wire is power that comes on when you turn on the key, yellow is constant power for memory.
Feb 19, 2012 | Kenwood Car Audio & Video
I have a 1985 4.1 cad coup deville I. replaced the motor,now I'm down to the starter wiring,6 wires i know the battery goes on the large post and the purple wire goes on the small post,that leaves 4...
OK, There should not be a "Tan" wire there. It is probably the "Red" or "Orange" wire that has faded real bad and just looks tan. It goes on the same post as the large black battery cable. It should be a 10 gauge wire. The other end of that wire goes to the "BAT" terminal on the alternator. (in case you want to check and make sure) The smaller black wires should be ground wires, They will attach to the transmission housing. Usually, there is a special bolt with a stud made on the end of it and a nut that secures the wires. As you said, the purple wire goes to the small post on the starter solenoid.
May 08, 2011 | 1985 Cadillac DeVille
2001 mitsubishi diamante windshield washer pump has 2 wires running to it...a black w/white stripe and a black. which is hot and which is ground ?
There is a good possibility that NEITHER is "ground' except when the switch is pushed. Many automotive circuits are controlled on the ground side. This allows a single wire to be run to the remote switch.The switch body is attached to ground.
Use a 12V test light: 1) Attach the clip to battery ground, turn key to the run position (but don't start the engine) and probe both wires. If one lights it is constant hot. The other will only be ground when the switch is pressed. 2) Move the clip to battery POSITIVE and probe both wires. The one that lights is GROUND. If neither lights the one that did NOT light in step 1 is switched ground.
If you get a light in both conditions then the pump would run continuously.
You can repeat the above having an assistant hold the switch, one wire should light the light in both the steps. Step one finds the HOT wire, step 2 the ground.
Mar 02, 2011 | Mitsubishi Diamante Cars & Trucks
I have a combination single pole switch. Light switch and receptacle. In have running in the old box 2 white, 2 black and a ground. How do I install the new switch to have power to the light switch and...
You are replacing old switch-receptacle device.
New device also has switch and receptacle.
You want switch to control light, but not receptacle.
You want receptacle 'hot' all the time.
You have 2 cables that enter box.
Each cable has white, black and ground wires.
Ground wires are twisted together and attached to green ground screws and not discussed more.
Screws on new device:
Side 1 of device: New device has dark screw(s) or brass screws on one side ... these screws are connected together by brass plate. This side is the Hot side of device.
Side 2 of device: Other side has 2 separate and unconnected screws. These screws are not connected in any way. Each of the 2 disconnected screws sits opposite the switch and opposite the plug.
Cables.
One cable comes from breaker box. This cable has a Hot and Neutral wire. The Hot is black. Neutral is white.
The other cable goes to Load (light). Black supplies power to Load (light), and white connects to Neutral.
If you are uncertain which is which, testing is shown below.
Connect the device:
Side 1 of device: Black Hot goes to dark colored screw(s) that are connected by brass plate. (This is only wire connected to this side of device)
Side 2 of device: Black that goes to Load (light) connects to screw that sits opposite the switch.
Side 2 of device: White Neutral connects to screw that sits opposite the plug
One wire is left .. the white from light. This white wire connects to white Neutral wire. Since white neutral is already connected to device, look on back of device to see if there is a quick-connect hole for you to shove wire into back of device. If device doesn't have quick-connect, then twist white wires together, and add a short jumper wire to device, and then all the whites are connected to neutral. Circuit is complete.
How to test for Hot and Neutral
Separate wires.
Turn on power.
Test each wire to bare ground.
Tester lights up on hot wire.
Now test hot wire to other wires.
Tester lights up on neutral
Nov 17, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
Cadillac sts wire diagram
1994 Cadillac Seville Car Audio Wiring Color Codes
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Gray/Black
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
pls rate
Dec 30, 2009 | 1994 Cadillac Seville
Temperture gauge
It's either a loose wire on the sending unit, or the sender itself. Or i suppose it could even be the gauge, but i'd bet on the one of the other 2.
Jun 04, 2009 | 2000 Cadillac Seville
Ignition module wiring on 85 f150
The red wire goes to constant hot and the white wire is on the key on/off. The green is a tach signal and the black is ground.
Jul 15, 2008 | 1985 Ford F150
Wire diagram for installation and where can i get the plastic inserts for the buttons
i just got the wiring for the sony xe-mk90II eq, heres a picture :
top right is the ground , bottom right is constant power, blue is the remote turn on. if you have a old wire harness around you can pull out the blue ,yellow, and black wires with the metal clip on and make than fit right where the wires should go. but make sure u rap the metal clips with electrical tape so the wires dont touch or you will fry it.
Feb 22, 2008 | Sony XE-90MKII 9-Band Car Equalizer
Dual XDMR7710 CD Player Logo
79 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
