Question about HP Office Equipment & Supplies
Where can I find a replace power supply for HP Photodmart320 series
    Sergeant:
  • 369 Answers
WHAT ACTUALLY IT HAPPENS yhe power supply is taking in or no befor u change it please let any electrician check it for u
may be a fuse prob or connection may be its not the power supply it could beyour printer controller board
CAuz it happend with me that i tried to let some body replace the powersuppy it was no problem with it
Posted on Jun 12, 2008
    Problem Solver:
  • 18 Answers
Use the part number supplied by
phoenixcomm above by going
on ebay, someone will have it.
    Scholar:
  • 87 Answers
You can also try radio shack, frys electronics, digikey (its online and a shop).
They have replacement store brand power supplies for computers, printers, notebook computers.
Bring the bad adapter in and look for the proper wattage/amp, current/volts, ac/dc power supply.
If you don't have the old adapter you can check the printer it self. Usually will give you a polarity diagram
(ie: - ----(x---- + )
how to read it:
my exaple shows that the outside of the plug is negitive
And the positive is in the middle
"x--- +"
There is usually a voltage and amperage listed too.
AC / DC Usually AC for a printer but check (if it is AC there wont be a polarity diagram since the plug alternates back and forth.
Amperage is very important.
You should get the minimum listed on the device but I recommend at least 1/2 amp over to prevent overloading the power supply (you can tell when they are overloaded by the heat)
-------- adventurous repairs
You could also open the power supply and see if the fuse is blown. They all have them. I don't recommend it since there could be another issue causing the fuse to blow like a failing component in the power supply itself. This kind of repair should only be done by someone who is familiar with electronics. If you have access to one that person probably has a power supply already.
Then there is Good Will or St Vincents. They always have plenty of power adaptors. Usually for 1$. Printers are always there. Check it out.
Those are my suggestions.
Posted on Jun 11, 2008
    Scholar:
  • 94 Answers
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Hi You are realy lucky... Just go to www.hp.com and under support put in you printer, and you will see replacement parts heres the link
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=partlist&model=Q8517A&modname=PHOTOSMART+A320+COMPACT+PHOTO+PRINTER&template=main&plist_sval=ALL&plist_styp=flag&bomlist=Y&strsrch=&keysel=%3F
and your ps part number is 0957-2120
Please double check I used "Photosmart A320"
Cris
    Scholar:
  • 107 Answers
Hi
if u want to find service center near by u please use below link
it is US service locator fill up Information & find it
http://hp.infonow.net/bin/findNow?ONE=1&CLIENT_ID=HP_LOC_USA_SRV&PAGE=Search.html&LANGUAGE=USA_ENGLISH
If this is useful for u please rate me ........
    Problem Solver:
  • 20 Answers
Ebay
and search amongst that lot
How to resolve PoE fault hp5400zl
Those switches have a lifetime replacement warranty. Find the number you need on this website: http://www8.hp.com/us/en/contact-hp/phone-assist.html
and have the serial number of the switch handy. have the switch plugged in and running and have a laptop and a console cable ready before you get HP on the phone. If it comes down to being a problem with a part they will either send you the part you need OR the whole switch depending on what the problem is with the switch. Most PoE faults are power supply problems. if your switch has more than one power supply be sure the connect both of them to power as HP POE switches that have more than one power supply, 1 power supply gives power to a certain portion of ports and the other power supply will give power to another portion of the ports. Much good luck!
May 21, 2014 | HP 24-port 10/100/1000 Poe Module For 5400...
I have a HP 1100PSC and the power supply is faulty. I want to know how the LITEON TL-130 0349 mc Rev.b is configured
if it is faulty,the best way is to buy a new one, or search fthe net for replacement/universal adapters
Mar 14, 2014 | hp psc 1100 series
0b000d 00000012
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Oct 11, 2013 | HP DesignJet 1050c plus InkJet Printer
Power supply has a continues blink instead of a solid led light.
HP skimps on power supplies, using a supply that has only a small margin of excess power. This causes the supplies to run under stress too often.
Make sure any replacement supply has the correct physical configuration for your system and replace it with one that is capable of 50% more power than the original rating; the cost difference is likely to be minimal and in any case lower than an 'original HP' unit of the same power rating that has now failed.
It is possible that a failed mother board or hard drive is causing your problem but you are risking well under $50 (for an ~400 watt supply) and will be getting a superior unit. eBay is a good source and you can seek a replacement using the Pavilion series name and then checking for your particular model number.
Oct 26, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
HP dv2000 fails when power supply connected
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
Jan 04, 2010 | HP Pavilion dv2000 Series Laptop Full...
Need tip size for viewsonic powere supply
insidecomputer_2070_4186448
Replacement Part Number: 1267-0526
Specs:
  • 40 Watt, 12 Volt AC Adapter
  • 4.8 mm Barrel Connector with Positive inside
  • Condition: New
  • Warranty: 12 Months
  • 100% OEM compatible, Guaranteed to meet or exceed OEM specifications
Compatible Models:
  • Hewlett Packard Jornada 680 Series
  • Hewlett Packard Jornada 720 Series
  • Hewlett Packard Jornada 728 Series
  • HP Jornada 680 Series
  • HP Jornada 720 Series
  • HP Jornada 728 Series
  • Planer LP150-BK
  • Viewsonic VG150
  • Viewsonic VG-150B Model
  • Viewsonic VG151
  • Viewsonic VP140
  • Viewsonic VP150M
Sep 07, 2009 | ViewSonic VG151 15" Flat Panel LCD Monitor
Hp compaq d530 400 watt power supply
You will not find a power supply for this case. Why would you want to upgrade such an old computer? Get yourself a new one with amply power for your needs. If you are one that upgrades regularly, get a standard case with standard components that can be upgraded without the hassle of replacing proprietary form-factor compnents.
Aug 02, 2009 | HP Compaq d530 SFF PC Desktop
Error 50.6 in hp laserjet 9500hdn
  • HP II/III series most likely cause is the ac power module is defective. Order the HP II/III Service 50 Error Repair Kit. If the quartz fuser lamp is burned out, order the replacement fuser on specials page. Slight possibility of loose connector on DC controller. See tweaking page DC controller could also be defective, but this is very rare.
  • HP IIP/IIP+/IIIP most likely cause is burned out quartz lamp. Order the HP IIP/IIIP 50 Service Error Repair Kit. Could also be a failure of the power supply.
  • HP 4/4+/5 most likely cause is burned out quartz lamp. Order the HP 4 Service 50 Error Repair Kit. Could also be a failure of the power supply.
  • HP 4L/4P/5L/5P/6L/6P most likely cause is a bad ceramic heating element.
  • All other printers most likely cause is burned out quartz lamp. In rare instances the ac power supply has failed. Even rarer, the DC controller is defective
Jan 22, 2009 | Office Equipment & Supplies
146 people viewed this question
Seeker5211
Seeker5211
